I'm so pissed
Old Jan 23, 2006 | 07:26 PM
drkenan's Avatar
Default I'm so pissed
I was driving home today and my steering column started smoking again. Every 6 weeks or so, one of the hot wires that leads to my ignition switch decides to overheat and burn up the switch and surrounding wires/harnesses.
So I know how to fix the problem as I do every time (this is the 3rd), but I was wondering if anyone has any suggestions as to what could cause a wire to continually overheat like this. I think I'm gonna have to trace the wire and see if it's shorting to ground somewhere. Any suggestions would be sssssooooooooo helpful. Thanks in advance.
Old Jan 23, 2006 | 07:28 PM
Jestnomen's Avatar
6th Gear
Default RE: I'm so pissed
Not much to say really. Just check all the wires for melting and black soot.
Old Jan 23, 2006 | 07:30 PM
tip5's Avatar
Atleast your passenger side window regulators didnt break today BOTH OF THEM. Im more pissed.
Old Jan 23, 2006 | 07:47 PM
brrman's Avatar
Check to make sure you haven't got some wires getting crossed causing a short. Check your harness to make sure al the connectors are correctly separated and cannot touch each other. That would cause a wire to burn itself out pretty quickly.
Old Jan 23, 2006 | 07:49 PM
Peteman187's Avatar
I had a recall on my car for an ignition switch. They told me at the dealership that people where having happen exactly what you said. Give em a call if the problem continues.
Old Jan 23, 2006 | 07:52 PM
drkenan's Avatar
Thanks for the help. Unfortunately the recall was only for '96 & '97. I've replaced that sucker twice and obviously there is some sort of underlying problem that needs to be addressed. I know in the harness that the wires are seperated enough, so it must be something further towards the battery. This is gonna take forever to figure out. [:@]
Old Jan 23, 2006 | 10:36 PM
Kellya4's Avatar
Is it the same wire that you have replaced already, or a different one each time?
Old Jan 23, 2006 | 10:41 PM
BFlan2001's Avatar
definitely sounds like you've got an exposed wire somewhere in the circuit
Old Jan 23, 2006 | 10:49 PM
tip5's Avatar
There needs to be a recall on the window regulators seeing how the factory put them on backwards in the 97 98 1.8t model. BS!
Old Jan 24, 2006 | 03:35 AM
siembad13's Avatar
damn......i have a 98
prady
Aug 7, 2011 08:13 AM
afour
Jan 16, 2008 01:47 PM
six14life
Nov 17, 2007 04:46 PM
