Im soo confused (Bulb Question)
Old Oct 3, 2007 | 09:31 PM
auditech79's Avatar
Default RE: Im soo confused (Bulb Question)
Oh man you need a bentley manual or something, you can't trace wires without a wiring diagram, and even with the diagram it can be quite confusing.
Old Oct 3, 2007 | 09:50 PM
erikas3's Avatar
ORIGINAL: auditech79
Yeah.. Im not planning to just start looking at them like this.. I noticed that there are 2 types of electrical tape used.. Wonder if thats how it's supposed to be or if someone already messed with it.. Probably going to take it to a mechanic anyways since I have no idea whether the brake light switch is still good. Note: Cruise control is also being cut off.
Old Oct 3, 2007 | 09:55 PM
auditech79's Avatar
If any electrical work has been done by the dealer under the dash there would be yellow electrical tape there. Its required for us to use that so someone else knows we have made a repair.
Old Oct 3, 2007 | 10:17 PM
erikas3's Avatar
Thanks for the info! Sure didn't know that! It's not the case though, just different electrical tapes..
I checked out the rear foglights and the housing for the right one is melted in! This sure sounds like a bad ground now..
Old Oct 3, 2007 | 10:19 PM
auditech79's Avatar
I would say more of a cross short inside the wiring harness. Those are really, really, really hard to find un-less you know where all the sonic welds are inside the harness.
Old Oct 3, 2007 | 10:36 PM
erikas3's Avatar
Darn.. Looks like this will be a major moneypit =(
Old Oct 3, 2007 | 10:43 PM
auditech79's Avatar
Well if you can get a bentely manual and someone with a multimeter then you can try to test ohms between certain things in the system. For example between the brake light switch to the fuse, then touch the wire to ground and see if there is resistance, things of that nature. If you look at the diagram and get resistance on a wire that shouldn't be there something is shorted and you know where it is in the car.
Like its in between the circuit breaker and the tail light bulb kinda thing, so at least you can find out if its the internal harness or a componet thats causing the problem. Hell its possible that its just the brake light switch. Only testing the wires will tell you.
Old Oct 4, 2007 | 06:15 PM
  #18
erikas3's Avatar
Is there a way to test the brake switch?
Old Oct 12, 2007 | 10:48 PM
  #19
erikas3's Avatar
Im soo relieved right now as I fixed it! Believe it or not, it was just the bulbs! 3$ and I have fully functional lights!
Now to fix cruise control.. =P
Old Oct 12, 2007 | 11:44 PM
  #20
hiwords's Avatar
lol well ask urself, do u rly need it? and wut year is ur car?
