install DV & it feels different
Old Mar 29, 2005 | 03:05 AM
hypnotiks's Avatar
Default install DV & it feels different
i install the OEM 710N DV today..... I feel like i lost a little power or i dont feel it to aggresive......before i felt it aggressive alll the time....what do you guys think?
Old Mar 29, 2005 | 03:08 AM
CheckMyVitals's Avatar
Default RE: install DV & it feels different
more than likely placebo. check leakage around the DV. have some one rev the car, getting the DV to release, feeling with your hand for some air blow off. even then, a little bit of blow off isn't going to actually have a noticible effect.
Old Mar 29, 2005 | 03:12 AM
black b5's Avatar
make sure the small vacuum line is secure on the valve......then trace that hose back to the recirculating valve under the intake and make sure it is secure as well.
i had the same problem and found the line loose at the recirc. valve...........pita to get at
Old Mar 29, 2005 | 03:15 AM
hypnotiks's Avatar
does the vaccum line has a clamp?
Old Mar 29, 2005 | 03:19 AM
black b5's Avatar
yes, at both the dv and at the recirc. valve
Old Mar 29, 2005 | 03:23 AM
hypnotiks's Avatar
oh...when i took out the old Dv it didn't notice if it had a clamp so i guess it could be that......also is there a benefit on changing the recirc valve?
Old Mar 29, 2005 | 04:02 AM
brrman's Avatar
make sure its not on backwards too
asdf7890
B7 Models
Mar 15, 2012 12:50 AM
brimhall99
Apr 12, 2008 05:11 PM
nlnfns
B7 Models
Feb 9, 2008 05:29 PM
a4sport
Nov 3, 2006 04:02 AM
swaprocks
Jul 19, 2006 11:15 AM
