Installed awe-apillar and..
Old Dec 3, 2006 | 12:17 PM
fher7096's Avatar
Default RE: Installed awe-apillar and..
Read the install manual very closely. That piece you did not use has something to do with it. It is under STEP 11. "Install the inline filter in the boost hose. Cut the boost hose and install the filter with the enclosed zip ties. THIS FILTER IS REQUIRED TO ELIMINATE ANY BUZZING NOISES FROM THE GAUGE UNDER BOOST" If you did install the filter then flip it around and hook it up opposite of what you have now. Hope this helps.
Old Dec 3, 2006 | 03:19 PM
18T's Avatar
18T
its not buzzing , i have a leak.
Old Dec 3, 2006 | 03:49 PM
Beer Mod's Avatar
If you cut and spliced the boost/vac line to the gauge, that is your problem. They will leak every time.
Old Dec 3, 2006 | 04:16 PM
18T's Avatar
18T
eh fak it, i think ill just buy resintall kit and do the piping to the mani again.
Old Dec 3, 2006 | 04:18 PM
18T's Avatar
18T
ORIGINAL: fher7096
that filter is enclosed in plastic and is yellow/orangish right? where do i place that thing so it doesnt get damaged?
Old Dec 3, 2006 | 08:41 PM
blacklabel's Avatar
where can you get the reinstall kit? i've been looking around for one, hasnt really been on the top of my list of things to do though
Old Dec 3, 2006 | 09:49 PM
fher7096's Avatar
I put it under the steering column before I routed the hose through the firewall.
Old Dec 4, 2006 | 03:44 AM
  #18
18T's Avatar
18T
ORIGINAL: blacklabel
i belive ecstuning has it. and many other places, or just go buy vac hose from an auto store.
Old Dec 4, 2006 | 07:26 AM
  #19
BadLuckAudi's Avatar
but you should really look to find the black tube used on large trucks its much more flexable and will actually work better
ORIGINAL: 18T
Old Dec 4, 2006 | 04:54 PM
  #20
18T's Avatar
18T
ORIGINAL: BadLuckAudi
ORIGINAL: 18T
black tube? you mean rubber vac lines?
