Installed awe-apillar and..
yes... use rubber vac hose...
i would just go and get a black plastic tee from home depot, ther like 15cents.
hook up the tee str8 to the vac hose then run the vac hose all the way to the gauge and right before you get to the gauge run a footlong piece of the nylon tubing 8inches into the end of the black vac hose put a zip tie around the end and goop it up with silicon...
then put a zip tie around all connections you made...
oh yea and get a new gauge, there not supposed to leak...
2 years runnin and no leaks yet!
ORIGINAL: luvin_the_rings
the gauge is leaking becasue i believe that the nylon hose is probably clamped somewhere between the ecu and the guage itself.
no not the big runner stuff its the same size as the stuff you have now but its a more flexible and dirable material its what people use on large trucks and it lasts 100 times longer
ORIGINAL: 18T
black tube? you mean rubber vac lines?
ORIGINAL: BadLuckAudi
but you should really look to find the black tube used on large trucks its much more flexable and will actually work better
ORIGINAL: 18T
i belive ecstuning has it. and many other places, or just go buy vac hose from an auto store.
ORIGINAL: blacklabel
where can you get the reinstall kit? i've been looking around for one, hasnt really been on the top of my list of things to do though
ummmm no I just buy it from my dads store I can see if i can find a part number or something.... its pretty common stuff on almost all big rigs
ORIGINAL: 18T
got a link by any chance?
kaptom540
Jan 24, 2008 08:53 PM
