Installes ECU+APR combo and the check engine wont turn off? WHY?
Old Apr 6, 2005 | 11:01 PM
cukilo's Avatar
Default Installes ECU+APR combo and the check engine wont turn off? WHY?
This is really annoying i installed the ECU+chip combo from APR with the same ecu number as the stock one but the check engine light wont turn off. I did this today does that matter, i mean does it go off in a day or 2?
Thanks
Old Apr 6, 2005 | 11:08 PM
Jestnomen's Avatar
6th Gear
Default RE: Installes ECU+APR combo and the check engine wont turn off? WHY?
Well the check engine light is on for some reason. You need to get the car scanned. Try autozone, it's free. Or better yet go buy a Vag-Com (which you should have already since you've started modding).
Old Apr 6, 2005 | 11:11 PM
cukilo's Avatar
I dont have VAG-COM where can i get it and how much is it? Also whats autozone?
Old Apr 6, 2005 | 11:15 PM
Jestnomen's Avatar
6th Gear
Vag-com can be purchased from http://www.ross-tech.com, prices vary by model.
Where are you located? Autozone is a auto parts store.
Old Apr 6, 2005 | 11:38 PM
cukilo's Avatar
I'm in Toronto Canada
Old Apr 6, 2005 | 11:42 PM
Jestnomen's Avatar
6th Gear
Hmmm well I don't know what to tell you. You can try unplugging your battery for a half hour. If the CEL comes back on after that, then you have problems that need to be addressed.
Old Apr 7, 2005 | 12:45 AM
TGPorsche96's Avatar
It takes 24 hours for it to go off dont worry about it yet if it keeps going then wait 48 hours after that contact apr anfd they will tell you where to go
Old Apr 7, 2005 | 04:16 AM
cukilo's Avatar
So this happened to you as well? Is this standard with APR chips that the light comes on and then dissapears after 24 hours?
Thanks
Old Apr 7, 2005 | 05:01 AM
cukilo's Avatar
Hey you were right i just went to turn on the car and the check engine light was not on any more. Thanks for your help. What is the fuel consumption difference between the stock and chipped ecu? Both on streets and highway driving?
Old Apr 7, 2005 | 05:16 AM
BFlan2001's Avatar
you should get slightly improved gas mileage
Krolmariusz
Oct 9, 2012 03:33 PM
FASTER
Jun 14, 2010 10:53 PM
virris88
Oct 16, 2007 09:57 PM
naptownlax54
Sep 25, 2007 12:26 AM
mikeysentra
Nov 6, 2005 05:21 AM
