Integra.. stomped me
Old Apr 9, 2007 | 01:51 AM
Beer Mod's Avatar
Default RE: Integra.. stomped me
Come on gusy some hondas are fast My buddy has a turbo 1.6 in his ex that will own my audi........
Old Apr 9, 2007 | 02:33 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: luvin_the_rings
its not like the 3.0 is anything amazing, a chipped 1.8 would rape a 3.0
i was wondering when someone would say that.
A gsr with basic bolt-ons should run high 14's. A stock v6.... well.... i think you know it isnt a 14 sec car.
Old Apr 9, 2007 | 07:09 AM
chaos92287's Avatar
you win some you lose some. there are PLENTY of cars out there that can beat ur car
Old Apr 9, 2007 | 10:41 AM
Amze's Avatar
Yeah, I wouldn't be to worried about losing to a "Teg" I mean at higher speeds it is lighter and that engine will pull pull pull.... just hope it wasn't an LS, then your good
Old Apr 9, 2007 | 11:07 AM
Hey_You's Avatar
Yeah, but wouldn't a chipped 3.0 beat a chipped 1.8T?
As for the integras, yeah, they're quick, my sister used to have a GSR
Old Apr 9, 2007 | 11:15 AM
Pablo_Ottawa's Avatar
ORIGINAL: Lopster99
2002 A4 3.0 Stock engine! But even being stock how can this be! God i am soo mad i really just want to get a 1.8T and mod the hell out of it!
Find that guy again, tease him with a race and watch him get nailed by the cops
Old Apr 9, 2007 | 12:10 PM
1.8TurboAudi's Avatar
i bet it was a Gsr......
Old Apr 9, 2007 | 01:22 PM
  #18
buschman's Avatar
I'm not sure why you are disappointed. You went up against a modded car. Honda or not. Stock or not. It was modded. To what degree you have no idea. In my Dodge Intrepid R/T civics and things were easy kills. But I picked on this one civic that completely messed my Trep up. The only indicator it was modded was that it was lowered and had very dark tint. So dark I couldn't see his a-pillar gauges. Turned out to be a stealthy turbo civic.
So don't sweat losing to a modded car. You have no idea what was in there. I'll second the comment that you should be happy you're driving home in the nicer car.
Mike
Old Apr 9, 2007 | 04:00 PM
  #19
veloracer's Avatar
One of the only things you can do to a 3.0 is to get a supercharger. PES has one for $5295.
+3 on driving the nicer car home.
[IMG]local://upfiles/24493/4301D3150A52498BAD0B0F236734D112.jpg[/IMG]
Old Apr 9, 2007 | 04:10 PM
  #20
nikos's Avatar
Don't feel bad.. I own a v6 A4 and a 250whp all motorHonda and yes although the honda is faster, I enjoy driving the audi so much more.. I guess I understand about your ego... but that is why I like my honda... got it for $450 before I dropped the $10000 motor in there.. It looks like crap but the expression on their face when I walk on them is something else..
Therefore, this is what I suggest you do (let me humor you)
I started with a acuratsx k24a2 shortblock
next I installed flywheel and TQed it to spec
then came the clutch and pressure plate
Now I am almost ready to attach the tranny... Just need 3 things...
a tranny...
It was pretty easy to install the tranny on the block since the block did not have the head yet on it, so it was easy to manuever..
here's how it looks attached
Next it was time for the head... But first we need to install the head gasket and dowel pins
Then we install the head on the block,,, and torque the head bolts according to the manual....
At this point... it is time to sleep so before I left, I wanted a mental image how it is going to look like...
note the 2006 Civic Si manifold that was cut to fit the k20a2 rsx type s head.. The tsx head is also a good head to use but I didn;t have a tsx head available in good shape.
So now... it is time to work on the timing chain and cover... so...
I remove the crank pulley
and install the cams gears, chain guides, tensioner... and at the same time set the motor at TDC while the motor is in time according to spec...
To do so... you have to align the cam gear marks
with the mark on the oil pump pulley that shows that the motor is in TDC...
It is pretty straight forward once you mess around with it because you cannot really miss a chain link...
Of course for this motor, I am using the tsx chain that is longer.
Once this was done, the tensioner is released to hold the chain in place
before installing the chain cover... I replace the oil seal
and the water gasket on that cover
then by using hondabond...
the chain cover gets installed.. then... the crank pulley is put back... and
since it needs to be torqued to 180 ft-lbs.... I use my moroso crank pulley holder...
Next... it is time to attach the crv bracket on the chain case..
followed by the hasport mount
next comes the alternator and starter
and then... it is time to drop da bitch in
But my audi on the intestate with the butt warmers on is something else.... So don;t be sad, be happy u drive an audi
