Interesting safety question :)
Old Sep 11, 2006 | 09:08 PM
Nenad22's Avatar
Default Interesting safety question :)
I`m curios...What happens when audi ran out of fuel and you are driving fast.I know when I turn of the car but give contact,power steer is off and brakes are braking very weak.I never waited long enough to see what happens,what if I am in curve and driving 60+,it could be dangerous.And how much fuel is in trunk when fuel light turns on?
Old Sep 11, 2006 | 09:57 PM
TDRILL's Avatar
Default RE: Interesting safety question :)
When you lose power (run out of fuel and car shuts down), your power steering and brake assist shut down too. Both of these systems will still work, but you don't have the power assist working so they will feel much heavier. The brakes feel weak, but are actually just as effective. You have to press a lot harder on them to make them work without the assist. The same happens with the steering, you can still steer, but it will take more effort to move the wheel.
It can be dangerous, but the systems are still working.
I believe you have around 2 gallons left after the light comes on. It should say in your manual.
Old Sep 11, 2006 | 10:10 PM
Nenad22's Avatar
Ok,thanks...I think that I have problem with fuel gauge cause when i fill my tank after light turns on it takes 12-13 gallons to fill it.
Old Sep 11, 2006 | 10:29 PM
Chingy's Avatar
When my fuel light usually comes on around 50 miles left the computer countdown. So at 25mpg that would be around 2 gallons.
Old Sep 12, 2006 | 12:18 AM
david9999's Avatar
Even when the countdown reaches zero, you have about 1 gallon left.
Old Sep 12, 2006 | 02:24 AM
Bondga's Avatar
Its not that dangerous to run out of fuel at 60, your engine stop running but that dosent mean its not turning. think about it if you hit the brake while in gear it stops fueling the engine same as if your out of gas. all the systems are running off of the serpitine(badly spelled) belts so as long as your moving their working. If it ever did happen leave it in gear as you slow, down ship to keep rpms up and go to nuetral when your going slow enough to safely stop the car with no power
Jeremy Decker
Mar 22, 2013 10:38 PM
Bluejediz
May 11, 2009 01:27 PM
powman
May 18, 2007 08:30 AM
_Adrian_
Nov 15, 2006 10:19 PM
A4hud_
Nov 14, 2004 03:34 AM
