Its going to be a long weekend....
Old Apr 5, 2006 | 12:40 AM
hypnotiks's Avatar
Default Its going to be a long weekend....
I should be getting my front and rear CR/Drill rotors with brake pads from ECS tomorrow...I will change this on friday. Also i wil change my Valve Cover Gasket. Just want to make sure I have everything. I will buy the Valve Cover Gasket. is there anything i need besides that.....screrws, other seals anything else. thanks in advance.
Old Apr 5, 2006 | 01:13 AM
TomRitt's Avatar
Default RE: Its going to be a long weekend....
just some silicone for the end of the vc gasket. Everything shouldnt take more then a few hrs, and a few beers
Old Apr 6, 2006 | 02:09 AM
hypnotiks's Avatar
is there a difference between buy the head cover gasget kit or Valve cover gasget kit from audi dealer or ECS tunning? This my be a dum question but i just want to make sure, head gasget and valve cover gasget are 2 different things? and if its like that can i change the head cover gasget being that I'm changeing the valve cover gasget? Also what does it mean when you guys say " torque the bolts down to 7ft/lbs" is there any special tools that i need?
Old Apr 6, 2006 | 02:33 AM
BadLuckAudi's Avatar
7ft/lbs is a measurment of pressure thats put on the bolts, its really not very much to do it right you would need a torque wrench but i think you can get by just doing them snug, but be sure you done over do it cuz the bolts are probably weak and your going in to aliminum and it could strip.... and the two kits are most likely the same thing, at least it sounds like that
Old Apr 6, 2006 | 02:42 AM
cudabob's Avatar
A valve cover gasket just keeps oil from coming out of the top of the engine and is simple to replace in a few minutes.. A head gasket goes between the cylinder head and the block and can take quite a while.....
Old Apr 6, 2006 | 02:53 AM
He said valve cover and head cover gasket, which i think are the same thing, now a head gasket is completely different but i think hes talking about two of the same
Old Apr 6, 2006 | 03:29 AM
hypnotiks's Avatar
head gasget, exaust gasget and intake manigasget......are these all go with valve cover gasget or is it more deep into the engine?
Old Apr 6, 2006 | 03:41 AM
thats much deeper thats for doing the head and all your doing is the valve cover and thats all you need should be like $20 or something
Old Apr 6, 2006 | 03:52 AM
hypnotiks's Avatar
ok this is where i stand.... My car is leaking oil on the peice that goes to the exaust (hope I'm explaining my self well) its creating a burning smell. so i decided that it my be the valve cover gasget....I started searching for post about spark plugs and ran into a post that mention oil inside the spark plugs...they said it could be the head gasget and etc.. so i just want to some info ...incase ihave to change the head gasget. I need to stop the oil leak.
Old Apr 6, 2006 | 07:05 AM
I think your probably looking at a valve cover gasket being the prob, you say its leaking out of the motor on to the exhaust, usually a head gasket wont cause that, with a headgasket you will get water in your oil and oil in the cylinders, like inside the motor not the outside like you say
02DolphinA4
Aug 20, 2007 08:41 PM
TeeterTawter
Apr 5, 2007 09:39 PM
TomRitt
Oct 6, 2005 11:57 PM
TomRitt
May 14, 2005 03:30 AM
1.8t20v
Apr 19, 2005 05:07 PM
