jackstand placement
Old Aug 10, 2004 | 07:14 PM
skibum0019's Avatar
Default jackstand placement
hey guys/gals,
does anyone know if there's a spot (or, more specifically, where that spot is!) to place jackstands on a 2000 A4 for an oil change, etc...?
thanks!
Old Aug 10, 2004 | 07:30 PM
ImolaS4's Avatar
Default RE: jackstand placement
I think it's well referenced in the manual, but IIRC, it is just behind the front wheels or just in front of the rear wheels (depending on which end you want to jack up). Both sites are about 6 inches away from the wheel wells. They have a cross member that attaches (welded) near the same spot. They are referenced by two button sized "nodules". Whatever you do, don't lift at the thin edge of metal that projects downward along the bottom of the car (set in about 3 inches) unless you have a jack that specifically fits that lip - you will damage the car if you jack it on that lip with the wrong jack.
Old Aug 10, 2004 | 08:12 PM
skibum0019's Avatar
thanks, dude. you da man!!
typical jackstands are ok for an oil change, right? (by typical, I mean something that I could get a Pep Boys or something...)
Old Aug 10, 2004 | 10:59 PM
Doose's Avatar
Yeah, there are diamond shaped indentations in the base of the panel. Just place the jack stand or lift right below those diamonds and you are good to go.
Old Aug 11, 2004 | 09:58 PM
David_K's Avatar
be carefull if you are placeing them anywhere else as they could puncture through anything!!!!!
A4speed
Dec 15, 2008 08:37 PM
Porschekid
Mar 25, 2008 12:21 PM
xerexb
Sep 30, 2007 11:32 AM
Colin519
Oct 26, 2006 09:19 AM
