Just finished boost gauge install and........
for some reason I am only reading 12 at idle. AWE says it should be 17-20. I am very new to turbos so I dont know what this means. It is boosting to about 10. Could this be the DV??
Ok I just checked all the line from the turbo and found a large hole in the y- hose behind the plenum. I will try to explain. Goes turbo to a metal hose (along side of the plenum) to this y hose. one of the y's goes into the plenum and the other goes down between the engine and firewall. If this is not clear enough I will go take a picture.
If it was a boost leak it still wouldn't read that high though. It would read lower. I would think it's just a mechanical problem in the gauge itself.
When you rev, how much boost does it read? (I'm guessing you have a fairly stock setup, no fiddling with boost pressure, correct?)
Here are the pistures. And yes that marker is inside the broken hose, it is ripped to shreds.
[IMG]local://upfiles/18144/8B30206F8F214F11A646C32FC60D2522.jpg[/IMG]
[IMG]local://upfiles/18144/1F4D7C3472B94CE6BE4C495F4908D6B5.jpg[/IMG]
[IMG]local://upfiles/18144/0E4AA38F842D42B580C66909B05A48F0.jpg[/IMG]
neur0tic
Apr 30, 2007 09:24 PM
