Just finished boost gauge install and........
Old May 13, 2006 | 05:16 PM
fher7096's Avatar
Default Just finished boost gauge install and........
for some reason I am only reading 12 at idle. AWE says it should be 17-20. I am very new to turbos so I dont know what this means. It is boosting to about 10. Could this be the DV??
Old May 13, 2006 | 05:40 PM
kextyn's Avatar
Default RE: Just finished boost gauge install and........
You're reading 12 PSI at idle?! That's not right. If you get any boost at idle it will be VERY minimal.
Old May 13, 2006 | 05:42 PM
kextyn's Avatar
Also, you're going to have to let us know some specs on your car before we can determine what, if anything, is wrong with it. What year, which chip, any other mods, etc.
Old May 13, 2006 | 05:44 PM
Mott Power's Avatar
Yeah man, that isn't right. Check to see if you set everything up properly. I'm sure it's just a faulty reading.
Old May 13, 2006 | 05:46 PM
fher7096's Avatar
Ok I just checked all the line from the turbo and found a large hole in the y- hose behind the plenum. I will try to explain. Goes turbo to a metal hose (along side of the plenum) to this y hose. one of the y's goes into the plenum and the other goes down between the engine and firewall. If this is not clear enough I will go take a picture.
Old May 13, 2006 | 05:52 PM
Mott Power's Avatar
If it was a boost leak it still wouldn't read that high though. It would read lower. I would think it's just a mechanical problem in the gauge itself.
When you rev, how much boost does it read? (I'm guessing you have a fairly stock setup, no fiddling with boost pressure, correct?)
Old May 13, 2006 | 05:56 PM
fher7096's Avatar
Sorry. 2002 a4 1.8t 59,000 miles. Carbonio intake. I have a bunch of pics but can someone tell me how to resize them to fit.
Old May 13, 2006 | 05:57 PM
fher7096's Avatar
When I drive it goes up to 10psi of boost and at idle it is reading 12 vac
Old May 13, 2006 | 05:58 PM
fher7096's Avatar
WOW I was not paying attention. It is 12 vac not psi
Old May 13, 2006 | 06:15 PM
fher7096's Avatar
Here are the pistures. And yes that marker is inside the broken hose, it is ripped to shreds.
[IMG]local://upfiles/18144/8B30206F8F214F11A646C32FC60D2522.jpg[/IMG]
[IMG]local://upfiles/18144/1F4D7C3472B94CE6BE4C495F4908D6B5.jpg[/IMG]
[IMG]local://upfiles/18144/0E4AA38F842D42B580C66909B05A48F0.jpg[/IMG]
texasboy21
Mar 4, 2008 02:07 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
xx18quattroxx
Apr 2, 2006 08:25 AM
y2karnival
Jan 27, 2006 04:04 PM
