Just got my car back!!!!
Old Apr 21, 2005 | 03:41 AM
Jeff's Avatar
Zombie Defense Force
Default Just got my car back!!!!
Well I just picked my car up from the shop today and man do I love it. I had a T3/T4 turbo with a custom down pipe no cat and custom exhaust manifold installed. To controller the boost I used a manual boost controller and for the fuel I used an AFC (air fuel controller). I have 550cc fuel injectors. A Greddy FMIC. And a boost gauge.
Old Apr 21, 2005 | 04:20 AM
PandaXpress's Avatar
Default RE: Just got my car back!!!!
nice man congrats on the mod enjoy the power i guess
Old Apr 21, 2005 | 11:25 AM
clconversion's Avatar
any pics ? hows the lag ? how much boost are you running ? cost ? hp-tq #'s ? lets go we need somemore info here before some might raise the flag [sm=bs.gif]
Old Apr 21, 2005 | 11:33 AM
CRAZYHAWK's Avatar
Enjoy.
Old Apr 21, 2005 | 01:42 PM
aRIf's Avatar
Wow... nice enjoy...
do u have to have different manifold to have T3/T4 turbo ?
what is your hp now ?
Old Apr 21, 2005 | 03:56 PM
Jeff's Avatar
Yes i needed a new exhaust manifold to bolt the larger turbo up. i only have about 250whp and 260ish torque tell i get my new clutch in. that is at 7psi of boost once the clutch goes in i will turn it up to 23-24psi. I will have pictures up asap when i get home. also a video of the dyno.
Old Apr 21, 2005 | 04:04 PM
aRIf's Avatar
I am planing to do same thing Jeff. so I dont want to trow my money away until then.. I am planing to get APC State I ECU upgrade. Do you have ECU upgrade but I dont know ECU upgrade will work with upgraded turbos or can u give me some little info... Thanks a lot.
Old Apr 21, 2005 | 04:14 PM
Jeff's Avatar
I do not have a new ecu. im using a ApexI AFC Select to controle the air/fuel. and a boost controller. the only problem that i have incountered with no chip is you need a dioid (spelled wrong) to fool the mass air flow sensor other wise you will not beable to run full boost. something cool about my car im using a 38mm waist gate that vents to the atmosphere and it sounds soo cool but very loud. i would also recomend that you up grade your intake system this is difficult because no one makes one for it. u have to custom bend the pipes if you use metal but it looks really cool. it cost me about 4500 for all the piping and installation plus 2 hrs of dyno time
Old Apr 21, 2005 | 06:23 PM
1.8t20v's Avatar
Sweeeeet!!!! Just cruious if internals and head are still stock? Is there much of a lag with that turbo setup?
Old Apr 21, 2005 | 06:38 PM
Jeff's Avatar
yes my internals and head are still stock. surprisingly there is not much lag at all i can hit full boost rather quickly
