JUST HAD MY SERVICE DONE OUCH..
Old May 13, 2005 | 10:01 PM
TomRitt's Avatar
Default RE: JUST HAD MY SERVICE DONE OUCH..
yea the whole process will hafta be done, uninstall and reinstall the belts. You could get it written on paper and signed that yours will be good until the next scheduled maintenance. Then when it does break, free motor for you!
bond007's Avatar
well basically i did speak to the shop owner.
I asked him do i need to take care of the tensioner ,he said that it was fine and if i wanted to he can do it .
Old May 13, 2005 | 10:13 PM
TomRitt's Avatar
Ahh your kinda stuck then. I would take it back and see if you can get a good deal by maybe saying he mislead you? Worth a try
Jestnomen's Avatar
6th Gear
Get it done! The tensioners are known to cause timing belt failures.
Old May 13, 2005 | 10:25 PM
BFlan2001's Avatar
like i said above, if you're going in there again, it's a good idea to replace your front cam shaft seals (5 bucks each @ ecs, you have 4), and snub mount (50 bucks from apr, ecs, awe...or 13 bucks from greedspeed)
jest, how important is it to replace the rollers? i don't think i've ever heard of them failing before....
Old May 13, 2005 | 10:59 PM
bond007's Avatar
IM upset i was such a cheap bastard and didnt get it done,now i pay for it...
so what exactly do i need to change
the tensioner or the tensioner rollers?
thanks
Old May 13, 2005 | 11:01 PM
TomRitt's Avatar
I'd change the tensioner and the rollers. I dont know much about the cam seals, i didnt change mine, but alot of ppl recommend changing them so you might as well,
I'm not sure how mechanical you are but changing this stuff isnt really that difficult, if you are local to me I'd help you out
Just noticed your a 2.8 that might make things a little more difficult. Maybe there's a 2.8 owner around that has experience, and could do it for a beer or 2
Old May 13, 2005 | 11:25 PM
  #18
BFlan2001's Avatar
you need to change the tensioner for sure. the rest of this stuff is just recommended, and can save you big bucks in the long run...
their is one tensioner roller, and one idler roller....they are about 40-50 bucks a piece though (ecstuning.com has them)....i've never heard of a roller going out, but i can't tell you that it won't happen if they aren't replaced....the snub mount is unrelated to your timing belt, it absorbs driveline shock during shifting, and it wears out...it can make your shifts feel sloppy. it's cheap, and it just pops on and off (once you have the front end off for the timing belt).....the front cam shaft seals can sometimes leak over time, they aren't necessary to replace but they're only 5 bucks a piece, so it's a good idea
yesss4
Nov 1, 2009 01:20 AM
pa4ul
Sep 14, 2007 11:29 AM
bplo
Jan 12, 2007 05:06 AM
chuckievi
Aug 23, 2006 12:01 AM
achTTung
Mar 7, 2006 11:07 PM
