just installed boost gauge, some questions
Old Nov 19, 2007 | 06:56 PM
cincyTT's Avatar
I'm make believe
Default RE: just installed boost gauge, some questions
Is your reading comprehension bad or do you just not pay attention? Read it again, he said what it does
Old Nov 19, 2007 | 07:04 PM
1.8TK3MP's Avatar
ya but what does the TB alignment do?, and how would i know if it aligned or not.....how long do you need to leave it in the on position precisly
Old Nov 19, 2007 | 07:08 PM
Bogie's Avatar
until it stops making that faint high-pitch sound. about 10-12 seconds or whatever.
Old Nov 19, 2007 | 07:28 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: 1.8TK3MP
Your DBC not DBW so it doesnt even pertain to you. And your going to have to look up what those stand for since im going to be mean like that
Old Nov 19, 2007 | 09:35 PM
Lazer Viking's Avatar
there is no limp mode on dbc cars...
check for leaks, mine spikes 7-8 holds 5-6, at about 25hg
Old Nov 19, 2007 | 11:25 PM
drp1489's Avatar
yea, i've never been above 5psi. i'm going to put in the 710N, check all hoses, and if it doesn't improve, i'll take it to get scanned. thanks everybody
Old Nov 20, 2007 | 12:14 AM
ty98a4's Avatar
mine car holds 5psi and spikes at like 6psi. and 20 vacume at idle. i think i have a leak somewhere. i was going to check it this week but now my car has bigger problems. your car will prolly be fine if you are getting a chip in it. just delete the codes now and see if they come back and then go from there
Old Nov 20, 2007 | 12:20 AM
  #18
Bogie's Avatar
ORIGINAL: drp1489
Once you check for vacuum leaks and replace the hoses (if that's one of the problems) and the boost stays low, keep in mind you could also have a faulty boost gage. It's improbable, coming from a reputable vendor, but things could always get by some QA depts, especially if it was checked on a Monday morning or Friday afternoon (or anytime like this week before a holiday).
Old Nov 20, 2007 | 01:08 AM
  #19
Audi_Skydiver's Avatar
What do you mean there is no TB alignment on DBC cars? I can do one on mine. It will make the hi-pitch noise and also will run like crap if I disconnect the battery for a while and then just start it w/out letting it sit in the on position.
Josh
Old Nov 20, 2007 | 01:16 AM
  #20
ILoveT's Avatar
I think the high pitch noise you're hearing is the fuel pump. As for running like crap, that could be your secondary air pump.
