K03 Back pressure
K03 Back pressure
OK so i ust got a boost guage( and fixed my limp mode problem, Huray!) and i've been watching the boost. I've noticed taht as i hit the higher RPMs my boost tends to drop off. Assuming this is normal, is this from the back pressure of the exhaust becoming to great or is it because of a Low A/R of the turbine. I've looked all over google but i can't find any specs on teh turbo. My main reason for asking is that if the drop in Bars is because of the high back presure at high RPMs i could get a new exhaust and eliminate this problem( I know i should get one neways but I'm just trying to figure this out) if it is because of a low A/R i would imagine that the K04 is nearly the same. I'm just trying to figure out what i'm gonna do with my car. So let me know what you think. OR if you have any specs on the K03
RE: K03 Back pressure
the ko4 still runs out of breath, you still get fall off in upper rpm's, i was not all that impressed.. the ko4 spools realy quick and gives ou a nice jolt and great low tq numbers but it still lacks top end..
