K04 Dyno results
Old Sep 11, 2007 | 05:51 PM
onepoint8tee's Avatar
Default RE: K04 Dyno results
I thought that was 202hp at the crank, not at the wheels. Looks good then.
Old Sep 11, 2007 | 05:58 PM
cincyTT's Avatar
I'm make believe
He said it calc maybe 15% drivetrain loss if you missed it. But he is not 100% sure on the percent.
ORIGINAL: sean1.8t
those numbers lookpretty muchspot on. DEFINATELY not low. PC-16 ususally makes only 220-230Awhp..
Fwd are making that kind of power with a k04-001, seems strange that an awd car is making equal to more power with more drivetrain loss.
Old Sep 11, 2007 | 07:11 PM
daesharacor's Avatar
ok, here's the deal.
I'm not sure if the number that the software is spitting out is whp or chp.
I want to say whp, since the software knows nothing about my drivetrain configuration.
On the other hand, they could have a built-in percentage loss for "most" drivetrains. Dad says he thinks he read somewhere that they include a 15% loss.
So... do the calcuations...
WHP = CHP * (1-.15) <---- this is how they turn the calculated whp from weight and acceleration into chp for the graph.
WHP = CHPreal (1-.22) <---- this is how they should calculate it for quattro.
therefore,
.85 x CHPsoftware = .78 x CHPreal
CHPreal = (.85/.78) x CHP software
So, doing just the maxes, 202 chp from the software (with assumed 15%) turns into 220chp (with assumed 22%).
That sounds about reasonable. Thoughts?
Old Sep 11, 2007 | 07:26 PM
cincyTT's Avatar
I'm make believe
That turbo at 14psi or so would make 200bhp with a stock exhaust and no fmic. So i would have to say thats an estimated whp figure.
Old Sep 11, 2007 | 09:11 PM
kextyn's Avatar
ORIGINAL: AudiCross
it should be around 21% for quattro. Aside from what i normally see you have a pretty smooth power and torque curve for the giac, which tends to be peaky
If you look at the real dyno graph from just the GIAC the torque curve looks quite a bit different.
Old Sep 11, 2007 | 09:15 PM
cincyTT's Avatar
I'm make believe
Its just estimates, its not a real dyno. Peak torque would be close to 2k-4k
Old Sep 11, 2007 | 10:54 PM
if you want real dyno for a chipped k03, look at my real dyno for a k03 chart, from the link on my first post above.
Old Sep 12, 2007 | 09:29 AM
  #18
kextyn's Avatar
ORIGINAL: daesharacor
That's what I was referring to. The graphs in this thread are just for comparison, they're not exact. But since you posted a real dyno of the GIAC chip as well as the graph you made with it we can see how different they are and use that to compare with the K04 graph.
I was just pointing out that the torque curve looks nice and smooth and peaks later in your graphs, but in the dyno graph it is peakier like mentioned before.
Old Sep 12, 2007 | 12:16 PM
  #19
Ah, gotcha. I thought you were referring to a graph published by giac.
broker23
Nov 8, 2013 07:14 PM
zelpdsm
May 19, 2008 03:46 PM
The Russian
Nov 7, 2007 01:32 PM
eliTTe
Oct 22, 2007 01:58 PM
dan
Jul 6, 2006 08:46 PM
