oil pressure?!?!?
Old Sep 1, 2007 | 02:17 AM
haveaseat's Avatar
Member
Default oil pressure?!?!?
hey guys gotta 01 2.8 and my oil pressure light came on for like 15 seconds then went off....i drove bout 6 miles and it came on again for like 15 seconds and went off on its own again?!? im thinkin the oil pressure sensor is bad? any1 know where it is? and where i can hook up a gauge to test it? let the car sit for about 3 hours and then tested again and drove home and the light didnt come on at all..motor sounds perfect too
Old Sep 1, 2007 | 06:53 AM
techbod's Avatar
Default RE: oil pressure?!?!?
# you test it there also
[IMG]local://upfiles/12092/0CE13252979443FAA62CB68B5249E111.jpg[/IMG]
Old Sep 12, 2007 | 12:36 PM
haveaseat's Avatar
Member
that picture looks to me as if its a 4cyl? i have a v6 30v the light was gone for about 2 weeks and now is coming on very sporadically and shutting off on its own, no knocking from the engine at all, so is there where i test for oil pressure on my motor? and if so what psi should i be looking for?
Old Sep 12, 2007 | 12:44 PM
techbod's Avatar
4/6/8/12 cylinder the sensor should be in the block as the picture shows and you need to tap into it to check the oil pressure, older cars had an oil pressure gauge and much more its a pity they didn't carry this on with the newer cars ( greedy sods )
pdxrado
Jan 28, 2013 06:35 PM
Dallas09
Aug 30, 2011 05:57 PM
kerNol
Feb 25, 2009 09:53 PM
rustyleskiv
Apr 11, 2006 01:15 AM
