K04 Question
Old Jan 3, 2007 | 03:19 AM
Bobthewise's Avatar
Default K04 Question
I'm not ready to buy a K04 but I just want to know how many internals I'd have to switch out or if I can keep it relatively stock.
Old Jan 3, 2007 | 03:36 AM
onepoint8tee's Avatar
Default RE: K04 Question
Try searching on "ko4" there is tons of info on the different k04 setups. Here, I'll jump start you: https://www.audiforums.com/searchpro...bmitbutton=+OK+
Also it helps if you put the specifics of your car in your signature-like what year/engine it is.
Old Jan 3, 2007 | 09:13 AM
david9999's Avatar
No internal changes needed for a K04. Just programming and fuel pressure regulator and the turbo
[/align]
[blockquote][/blockquote]
Old Jan 3, 2007 | 09:39 AM
Wrench's Avatar
That itfuel, turbo, and program wow how much psi can u run with that setup? David9999
Old Jan 3, 2007 | 03:20 PM
Slowb5's Avatar
wrench, the tuning comes in the program you get along w/ the ko4 upgrade. the fuel/timing/boost levels are all taken care of by the chip. the ko4 will do 19 psi, i wouldnt reccommend much beyond that. go w/ the pc-16 file by giac, good stuff. :thumbsup:
Old Jan 3, 2007 | 03:31 PM
Your gunna need exhuast, injectors, afpr, and a fmic to use the pc16. All you need is the 5bar fpr with the basic k04 chip.
Old Jan 3, 2007 | 03:59 PM
JohnnyBravoA4's Avatar
most people who go bt dont even change internals..
Old Jan 3, 2007 | 11:55 PM
Bobthewise's Avatar
thx for the help
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
