k04 times
Old Oct 29, 2005 | 11:09 PM
  #21
InsaneHatter's Avatar
Default RE: k04 times
weights not gonna matter on a dyno.....
weight will matter on track times but not on the dyno....
The only thing weight wise i can think of that will matter is unsprung weight i.e. rotors, drive shafts, wheels , tires... crank pulleys and other pulleies... other than that inside weight wont matter
Old Nov 3, 2005 | 12:14 AM
  #22
SoopaSexyS4's Avatar
thanks for your help. i think i might go with the Awe tuning kit, if they have a sale during Christmas, i will purchase then. i was wondering, if any of you have that setup, how is it working for you? what times would i get with the ko4 kit (exhaust included) in a quarter mile and 0-60. oh, yeah, one more thing, if anyone knows this, what mileage would i get with the k04? once again, thanks for all your input.
Old Nov 3, 2005 | 12:22 AM
  #23
Dudek12's Avatar
how much can you get a ko4 kit for and whats the best ko4 kit (most HP) you can buy
Old Nov 3, 2005 | 02:34 AM
  #24
audiboy1618's Avatar
Giac pc-16/j31 ko4 setups own. They have the fastest ko4 times.
Old Dec 21, 2006 | 10:14 PM
  #25
SHARKBITEATTACK's Avatar
So it’s not possible to run mid 13's on a K04? I thought that K04 A4's were equivalent or slightly faster if tuned well to stock S4's which run high 13's.
Old Dec 21, 2006 | 10:21 PM
  #26
01A4T's Avatar
I dont think that stock WRXs are 15 second cars. From my experience a well driven '02+ WRX will do low 14's.Im not too sure how we got on the WRX topic, but i think a K04 would at least be good for low 15's maybe high 14's. Correct me if i am wrong......
Old Dec 22, 2006 | 12:26 AM
  #27
sean1.8t's Avatar
15s from a someone like C&D. pretty conservative. keep in mind it matters who is driving the car. for instance, i've seen a completely stock '07 STi pull a 12.8xx 1/4. but they claim mid to high 13s. just food for though..
and 235Awhp not a chance, maybe 235whp but that would still be hard
Old Dec 22, 2006 | 03:23 AM
  #28
whitejeepXJ's Avatar
a stock WRX runs lower than 15.2 for sure cause i ran 15.3 with a stock k03 and a chip with the CEL on because my MAF was reading 0grams of air. since i got my MAF problem fixed my car pulls much harder and peaks at 18psi so i figure ill run a solid 15.0-15.2 next summer at the track.
stock WRX is in the 14's guaranteed!
ORIGINAL: ByPopularDemand
WRX run 15.2 stock. ive seen it time and time again. now i did see a stock srt-4 with just a short shifter pull consistant 13.9
Old Dec 22, 2006 | 02:43 PM
  #29
MissionCtrl's Avatar
maybe this will help.....
Dear Josh,
Thank you for your email. Nope you need to run the mods listed below. The power gains are approximately ~240hp - ~275hp depending on how healthy the engine is and if your intercooler is quality one. The biggest problem if the file doesn't run right is if the intercooler isn't top quality. The chip is 1.4 bar on most cars through the mid-range and 1 bar at 5,500 - 6000 where peak horsepower is measured.
The following is a list of the mods that are required for the PC16 file:
[ul][*]FMIC that will keep IAT's below 50 degrees Celsius.[*]3 Bar Fuel Pressure Regulator.[*]31 lb \"red top\" Bosch Motorsport injectors.[*]02 sensor with less than 50,000 miles on it.[*]Spark plugs with less than 10,000 miles on them.[*]Fuel Filter with less than 50,000 miles on it.[*]A clean Air Filter. [/ul]
If you are planning to upgrade to the PC16 file make sure you have all of the above required components.
For additional sales information please contact your local authorized GIAC dealer. You will find a complete list of full installation and flash centers on our website http://www.giacusa.com/dealers.php
Regards,
Andrea
GIAC
Automotive Programming
cdl5583
May 19, 2006 03:14 AM
EuroS4
Oct 18, 2005 04:44 AM
ExpLlclT
Aug 24, 2005 02:35 AM
njch412
Jul 30, 2005 10:20 PM
Mykdiver
Aug 21, 2004 04:44 AM
