k04 turbo question
Old Mar 2, 2007 | 08:02 AM
Philthykins's Avatar
Default k04 turbo question
http://cgi.ebay.com/ebaymotors/K04-K...QQcmdZViewItem
will this turbo directly replace my old k03 without modification?
i know it says audi "twin turbo" meaning the S4 but im still curious. im trying to find a replacement for my worn out k03 with 140k on it.
Old Mar 2, 2007 | 10:33 AM
akielb's Avatar
Default RE: k04 turbo question
Thats so cheap it has to be crap. #1 it is not made by Borg Warner (who makes all K04 turbo's) #2 I wouldn't trust it to last very long #3 I wouldn't trust it to even act the same as a K04 from BW - so you might have a programing issue when you get the K04 file from GIAC (this is not an option is you want to see any gains over your stock turbo).
My sugestion - if you have a bad turbo - go to G-popshop.com and either purchase a K04 spec turbo(around $600) - or have your K03 rebuilt into a K04 spec turbo cost is $425 +25s/h
I wouldn't feel secure knowing that turbo might fail at any moment - and hope that when it did fail it didn't send somthing into the engine and blow that too
Old Mar 2, 2007 | 12:35 PM
Lazer Viking's Avatar
not to mention it wouldnt bolt up any way if it was made to fit s4's
Old Mar 2, 2007 | 03:03 PM
A4Rollin's Avatar
i wouldnt trust buyin turbos off ebay, you never know what is wrong with it. Be sake and get the rebuild or buy a nw one.
Old Mar 2, 2007 | 11:26 PM
widgget's Avatar
you will need supporting mods if you are goign to install a K04, yes it is a direct bolt on part but you still need propper airflow through your engine along with other factors to consider. i just put my second K04 in due to what i believe is was too much back pressure from my stock exhaust and cat. you will need the follow parts to properly support a K04:
K04 Chip Programming
Front Mount Intercooler
Aftermarket Exhaust
High flow Cat
Upgraded DV
You will also likley want to use a new waistgate valve to smoothout the power band, but isn't nessary.
I am regretting not doing the exhaust, cat and FMIC in my car first. My K03 started squealing so i needed to replace it anyway so i went K04, but am now on my second one.... and the worst part about it is that i knew better but desided to "chance it" until i could get the exhaust done. It's always better to do it right the first time, you will save yourself time and money. I'm scrambling for the exhaust and cat before i hurt it again. Just my $0.02.
Old Mar 3, 2007 | 12:57 PM
david9999's Avatar
Well, no you don't need a high flow cat, nor a FMIC for a K04. However, they will help. A less restricive exhaust is however recommended.
Old Mar 3, 2007 | 03:21 PM
Bondga's Avatar
the compressor on that thing lookls like platic. Is it made by Tinker Toys?
EvoTillIDie1
Mar 5, 2014 10:42 PM
98A498
Oct 12, 2006 08:06 PM
keko2004
Aug 30, 2006 02:44 AM
zat0rsk1
Aug 17, 2006 11:36 PM
west2005
Aug 13, 2005 06:46 PM
