K04 vs Chipped
Old May 5, 2006 | 05:49 PM
02TurboA4's Avatar
Default K04 vs Chipped
Here is what I'm looking at doing and need some advice. I would like to spend $2000-$2500 on some performance parts. I need the car to still be reliable as it is my daily driver. I was looking at getting it chipped, a cat-back exhaust and FMIC. Or going the route of a K04 and yes I know I need a chip for the K04. How much performance/HP difference would I see with the K04 verses chipped? Any suggestions would be appreciated. Thanks
Update: Forgot to mention the car is a 2002 1.8T manual w/quattro
Old May 5, 2006 | 05:53 PM
tip5's Avatar
Default RE: K04 vs Chipped
go for a chip and suspension
Old May 5, 2006 | 06:00 PM
02TurboA4's Avatar
I have the sport package and the only other thing i plan on duing to the suspension is better sway bars. This mod is not in this buget, I was already pretty set on getting better sway bars. Thanks for the suggestion
Old May 5, 2006 | 06:45 PM
PandaXpress's Avatar
go with GIAC or REVO
if u want i say start off with the stage1+ which is large injectors then
later move up to the K04
Old May 5, 2006 | 07:04 PM
02TurboA4's Avatar
Thats what I was thinking. Start with stage1+ then move up to the K04. Anyone know how much HP would the K04 add to stage1+? Thanks for the suggestion
Old May 5, 2006 | 07:08 PM
here are some numbers with GIAC
http://giacusa.com/programs.php?mpid=3
GIAC performance software for the 2002 - 2005 B6 A4® 1.8T smoothly delivers a 30-38 hp and 55-60 ft-lbs gain.
GIAC offers two additional performance options to take greater advantage of some common bolt on hardware upgrades on the B6 A4 1.8t. The FXK03 and FXK04 chips are specifically designed to accommodate GIAC approved 36 lb injectors. This is an ideal upgrade for cars with exhaust, intake and, in the case of the FXK04, the K04 turbo. The FXK03 setup can yield up to 70 – 80 ft-lbs and 40-50 hp gains, while the proper FXK04 setup will allow another 15-20 ft-lbs and 18-28 hp over the FXK03.
and revo BI are about the same numbers
and their K04 claims 255hp/310tq
Old May 5, 2006 | 07:18 PM
02TurboA4's Avatar
Thanks PandaXpress
Old May 5, 2006 | 10:32 PM
BadLuckAudi's Avatar
i like the k04 but a cihp is good
B5Project
Feb 16, 2009 03:31 PM
fumoazul99
Jul 19, 2008 07:15 PM
slamer32
Sep 25, 2006 03:32 AM
Audinam
Jun 13, 2006 02:51 AM
Spdrcr7882
May 23, 2006 04:35 PM
