kazoo sound problem!?!?
Old Sep 4, 2006 | 04:26 PM
fritz's Avatar
Default kazoo sound problem!?!?
i have a 97 1.8TQM with about 133k on it. when i start the car in the morning, i hear a whizzing/kazoo/zzzzzz/ sound and i can really hear it get louder when i turn the steering wheel. then, once i guess the egine warms up, it goes away.
i suspect it to be a belt but it was changed at 85k.
what do you guy think it is?!?
Old Sep 4, 2006 | 04:33 PM
techbod's Avatar
Default RE: kazoo sound problem!?!?
does the starter motor shut down when it should or is it still cranking when engine is started??
Old Sep 4, 2006 | 04:38 PM
A3Night's Avatar
Perhaps someone stuffed a bunch of kazoo's in your tail pipe?
http://videos.streetfire.net/video/B...934FB999C2.htm
Old Sep 4, 2006 | 04:45 PM
techbod's Avatar
[sm=lol.gif] love it
Old Oct 11, 2006 | 06:19 PM
fritz's Avatar
bump up...
any possible solutions?
Old Oct 11, 2006 | 06:22 PM
aRIf's Avatar
1-check your steering fluit
2-could be bearing
Old Oct 11, 2006 | 06:24 PM
onepoint8tee's Avatar
Could be a failing power steering pump or low fluid if the sound is affected by turning the wheel. Once its warmed up the fluid circulates enough to quiet down. Check your fluid level, and next time you do a cold start have someone sit inside and turn the wheel and you look under the hood and listen and try to pinpoint where the sound is coming from.
TippmannX7
Sep 21, 2008 01:10 PM
Scott26
Aug 29, 2008 03:18 PM
bigdyll
Mar 16, 2008 01:04 AM
paradisnuts
Dec 11, 2007 01:50 PM
Shaunp05
Jun 25, 2005 01:16 PM
