Keeps Dieing. . .
Old May 23, 2007 | 02:30 PM
Audi A Fizzle's Avatar
Default Keeps Dieing. . .
So i'm driving to work this morning, im half way there (about 15 mins of driving) and in mid travel my car just cuts out and dies. . . the only light that comes on is the little red battery light. I turn the key completely off and restart it, runs fine for a few minutes then repeats. I tak it to les schwab to have the battery tested and they say it has plenty of life and they also claim the alternator is fine too. . . PLEASE HELP
Any idea?
It did this once a while ago, maybe 2-3 weeks ago, and has been running fine ever since.
Thank you in advance!
Old May 23, 2007 | 02:41 PM
techbod's Avatar
Default RE: Keeps Dieing. . .
what volts is the alternator giving to the battery?? it should be 14+
Old May 23, 2007 | 02:42 PM
ironman's Avatar
check all the connections from battery to engineand the alternator, you could have a bad lead and lose connection, ive had taht b4 it kinda sucks but easy fix if it is
Old May 23, 2007 | 02:44 PM
the battery connections are clean and tight. . .
i will be sure to watch the volts on my way home
where was your bad connection??
Old May 23, 2007 | 02:55 PM
techbod's Avatar
its not a question of where ( the system either works or it dosnt ) bad alternator = low volts to the battery should be 14v, bad battery = low volts approx 12v or less before cranking and if its just clicking then its the cranking amps and battery is dead try boost starting it?
Old May 23, 2007 | 03:05 PM
boost start?
Old May 23, 2007 | 03:08 PM
techbod's Avatar
jump start from another car/battery, jump leads I call them
Old May 23, 2007 | 06:57 PM
tractioncontrol's Avatar
Does the light come on before or after the car shuts off?
Old May 24, 2007 | 12:42 AM
aaroncoffman's Avatar
Ouch and from what im reading you just recently bought your audi right[&:]? Try checking your spark plugs, plug wires, etc.
Old May 24, 2007 | 08:57 AM
The light comes on right after it dies, within half a second. . .
Yeah i just bought the vehicle not too long ago, i did re-gap the spark plugs and looked around the wiring, nothing that i can see should be an issue!?
KnoxAudi0711
May 9, 2008 11:43 PM
turbo kraut
Nov 4, 2007 09:30 PM
Anos
Mar 27, 2007 05:43 PM
AudiCross
Mar 26, 2007 04:07 AM
zeshkani_usa
Mar 18, 2007 03:33 AM
