Key Fob Question
Old Oct 11, 2005 | 01:01 PM
cdf619's Avatar
Default Key Fob Question
Bought an a4 last week and only has one key. Looking to buy Key blade and Fob on Ebay. Question is, my key fob is 8z0 837 231 b with 315mhz. The one on ebay has the same number but ends in A not B, and has 433 mhz. Will this key still work? Thanks.....
Old Oct 11, 2005 | 01:07 PM
Jestnomen's Avatar
6th Gear
Default RE: Key Fob Question
Open up your key fob and look for the FCC ID code. Make sure it matches to the ones on ebay.
Old Oct 11, 2005 | 01:30 PM
cdf619's Avatar
Thanks for the reply Jestnomen,
I am probably just blind or confused but the the numbers I see are the ones i listed in the orignal post. Will the number start with fcc#. I was under the impression that 8Z0 837 231 B was the fcc# but I am probalby wrong. The only other concern is the difference in frequencies mine 315 the one on ebay 433mhz.
Old Oct 11, 2005 | 01:39 PM
Jestnomen's Avatar
6th Gear
Well if you pry your key apart as if changing batteries you'll see something like this:
I don't know about the frequencies. I do that almost all of the ebay auctions list the FCC ID code. When I bought mine from ebay I just matched them and it worked fine.
What year is your car?
Old Oct 11, 2005 | 02:01 PM
cdf619's Avatar
Its an 02. Based on the image you attached my fcc # is the 8Z0 837 231 B and lists the frequency right after. Mine as you can see is a litlle different. Mine does not say fcc # and it the numbers are extremely small.
[IMG][/IMG]
I emailed the seller to see if he might know the difference between the two. Thanks for your help.
[IMG]local://upfiles/11278/34C1F6058E264BA8A8E26F7D6E1BF327.jpg[/IMG]
Old Oct 11, 2005 | 07:45 PM
modifieda4's Avatar
Jestnomen, nice pic
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
