Keys
Old Feb 10, 2005 | 08:30 PM
jason745's Avatar
Default RE: Keys
Jest,
remember the A6 remote works too
I've confirmed it myself. You can also buy a used key and buy a generic blank cut and just replace the key part, it's pretty simple, took me about 5 mins to replace and program the key. My dealer cut it for $10, so like jest said, you need to call and find out if they'll do it.
Here's my thread: https://www.audiforums.com/m_33706/m...y/tm.htm#35969
Old Feb 11, 2005 | 09:46 PM
sdaudi's Avatar
Default RE: Keys
what's the "immobilizer"? someone told me that not any uncut key will work. it has to have the "immobilizer" chip in it in order for it to start the car. otherwise, it's only good for opening the doors. anybody know what i'm talking about?
Old Feb 13, 2005 | 03:49 PM
jason745's Avatar
Default RE: Keys
ORIGINAL: sdaudi
http://www.audiworld.com/tech/misc10.shtml
What year is your car? They started putting immobilizer chips in after a certain year, I cant remember right now and have to run out.... I'm sure someone knows off the top of their head.
Old Feb 13, 2005 | 05:29 PM
Jestnomen's Avatar
6th Gear
Default RE: Keys
There were no immobilizers installed in US cars.
Old Feb 14, 2005 | 08:00 PM
sdaudi's Avatar
Default RE: Keys
is immobilizer same as 'transponder'?
i saw some ads on ebay that said 'transponder' included more $$$). and some said no transponder.
Old Feb 14, 2005 | 08:47 PM
Jestnomen's Avatar
6th Gear
Default RE: Keys
yeah same thing.
Old Feb 16, 2005 | 12:35 PM
99AudiA4q's Avatar
Default RE: Keys
Hey so i can reprogram my remote even though i only have one? wat do i do take the key off the remote and just follow ur instructions?
Old Feb 16, 2005 | 01:00 PM
  #18
jason745's Avatar
Default RE: Keys
ORIGINAL: 99AudiA4q
Yes you can program it with one remote, but you have to have two keys. I only had one initially, so I bought my remote and key off ebay. Then took the key to the dealer to be cut. He asked if I wanted it programmed and I said no. Now once you have two keys follow these instructions:
Code:
 1. Take your first key and insert it into the ignition. Turn it one click forward.
 2. Roll down your window just in case. Step outside the car, and lock the car with the second key.
 2b (optional, it might take a few times). Take key out of lock (it wouldn't program with the key in the lock for some reason)
 3. With your key remote press the unlock button. The lights (my brake lights) should flash.
 4. Now lock the car with the remote, and then unlock it. (it should unlock your doors).
 5. Remove the key from the lock and the key from the ignition, and try it's function.
 I couldn't get an uncut key, so I bought a a6 remote with a cut key ($15)  and then just a blank blade ($20)
 (the dealer cut it for $10 bucks), and followed these instructions to swap blades:
 Swapping keyblades…
 The keyblade is held in place with a small roll pin, flip out the keyblade halfway and you'll see it.
 To separate the keyblade from the device, just hammer out the pin with an appropriately sized punch or nail.
 After that, you should be able to pull the keyblade away from the device.
 If you can remove the keyblade properly, you can figure out how to reinstall it onto a new remote on your own.
 When reinstalling, just make sure the side of the keyblade with the logo “Huf” is facing the opposite side of the
  panic button when flipped outward, or else the roll pin would not go in
Old Feb 16, 2005 | 01:59 PM
  #19
Jestnomen's Avatar
6th Gear
Default RE: Keys
correct...my car came with NO remotes, just the two keys. And the new remote I bought programmed fine.
Messiahlee
Jan 9, 2019 02:42 PM
ParadoxZero
Feb 14, 2014 09:39 AM
soccergk
9
May 4, 2009 09:12 PM
wanger727
Mar 30, 2009 03:08 AM
piloturco
Sep 10, 2006 11:07 PM
