View Poll Results: A poll
good
100.00%
bad
0%
piss off!
0%
Voters: 11. You may not vote on this poll
Koni coilovers?
Old Jul 27, 2005 | 03:30 AM
Simone's Avatar
Default Koni coilovers?
i live in mn so i would want to adjust the height with the seasons...
i'm not a rich man, is this the best suspension option for my $$$?
Old Jul 27, 2005 | 06:41 AM
flyinb501's Avatar
Default RE: Koni coilovers?
I think koni are a pretty good bang for the buck.
Old Jul 27, 2005 | 11:30 AM
juju4uofa's Avatar
Koni has great coilovers. Adjusting the height isn't very simple though. It's not bad but you wouldn't want to do it too often.
Old Jul 27, 2005 | 08:26 PM
Yuikio's Avatar
I like mine. And adjusting the height isn't that bad, it does take a good amount of tedious wrenching-reposition-check height-repeat, but yeah, they're good.
Old Jul 28, 2005 | 01:54 AM
trailboss's Avatar
ORIGINAL: Yuikio
What Yuikio said, but its like that for most every coilover out there. On the koni's front are damping adjustable and height and the rears are height adjustable and i believe damping, i never set the damping on the rear because i was in a rush. The only problem with konis are the rear coilovers. It is like a sleve that goes over the shock body and is bolted down by pin head allen keys, if any force is exerted on the rears the sleve will spin around the shock body and it will go nowhere. Also it is a breeze to lower your car b/c your decompressing the spring but to raise it you may have to pull the coilover off and compress the spring because it's just to much force it all depends on how low the car is already. I had to do this because my front was soo low. Otherwise they are great.
HibiscusRedB5
Feb 10, 2011 05:47 PM
somebody5788
Oct 23, 2010 09:13 PM
kriptonik
Jan 21, 2008 11:55 PM
S4evr
Nov 1, 2006 10:37 PM
rons01a4
Oct 23, 2005 04:02 AM
