Leak and Oil Light when pushing it
Old Oct 5, 2007 | 12:16 AM
airy52's Avatar
Default Leak and Oil Light when pushing it
So ive been leaking sonmething for about 6 months, maybe a spoonfull or 2 spoonfulls of fluid, ( not very much) and it looks pretty clean, every night i park my car in the garage, i cant figure out waht it is
ive checked my oil, brake fluid, power steering fluid, radiator stuff, all that, and today i checked the front differential fluid and it was full.
It is leaking out of the hub area that connects the drivers front wheel to the thing, (from the outside of the wheel, its the second boot in) and it looks like someone tried to replace the metal clamp that used to be on it with a strong, tightly tied, zip tie.
Does fluid flow through that boot and is that whats causing it to leak only after i drive it?>?? let me know. 2001 audi a4 1.8t tqt
btw i havent checked the transmission fluid and dont know how to on a b5. thanks if u can tell me!
erik
edit: almost forgot, when i push the car real hard, like for a half hour the oil can shows up on my led screen (which is perfect thank you very much!) i checked my oil and its at the perfect level, if not a 1/32 inch too high, also i changed it like 3 months ago.
capn
Dec 26, 2014 11:24 PM
Got_A4
Apr 13, 2011 05:27 PM
justinclink1
Oct 9, 2010 03:47 AM
Mr. Phil
Oct 28, 2009 03:16 AM
