only pushing 6 pounds of boost
Old Oct 3, 2010 | 12:12 AM
justinclink1's Avatar
Default only pushing 6 pounds of boost
my 2000 s4 is only pushing like 5 or 6 pounds of boost on the boost gauge i tryed a diff boost gauge but it reads the same its not leaking boost cuz it holds steady at 5 to 6 pounds got and clues ??
Old Oct 3, 2010 | 04:13 AM
josh_easlon's Avatar
Your car is running in limp mode. Is your check engine light on? I would take it to a shop, or to o'riely's and grab an obd2 Diagnostic tool and see what codes are being thrown.
Old Oct 3, 2010 | 06:18 AM
no theres no engine light on i own a odb2 scanner when i plug it in its says error on it and somtimes my abs light comes on and the brake light flashes? and there is 3 beeps. also my oil dip stick smells of gas?
Old Oct 3, 2010 | 06:41 PM
cu52's Avatar
Have you actually pressure tested to find leaks? The turbo will over spool to make up for a leak causing a premature failure. Start there.
make one of these: http://www.awe-tuning.com/pages/shar...ssure%20tester
10PSI to test it.
Old Oct 3, 2010 | 09:11 PM
If you had a boost leak, it would spike greater than 5psi. It's sustaining 5psi max suggests that your car is in limp mode. If your obd2 tool isn't reading... Then go somewhere that will have something compatable. If any warning light in your car is flashing, then there is something more serious with whatever light is flashing. Your brake light will flash when you need to change your brake pads. Or maybe the sensor is bad or loose. I'm not sure about this, but I think if the car determines the breaking to not be suffecient, the car will go into safe mode. As far as your oil smelling like gasoline, I would change your oil and see if gas is somehow getting into the system... Which is doubtful. Some synthetic oils have a funny smell to them when they are hot. It could just be that. Gasoline in you oil would break down something fierce and destroy your engine.
Old Oct 4, 2010 | 03:16 AM
gas is most deff getting into the oil some how. i smelled the oil before i changed it and it smelled like gas 3 days after i changed it and it smells like gas still i used full synthetic mobil 1 so i know its not the oil but i heard it could be a leaky injector?
Old Oct 9, 2010 | 03:47 AM
vooo5269's Avatar
a leaky injector would cause it to run rich but im pretty sure the gas would still burn off when the spark plug fired. are you smelling the gas on the dipstick tube or when you drain the oil?
mitchholmstrom
Jun 25, 2008 09:23 AM
A4induced
Jan 11, 2008 08:14 PM
Apdl
Aug 7, 2007 08:04 PM
Blown87camaro
Jun 12, 2007 08:58 PM
