Leaking FPR?
Old Dec 9, 2007 | 03:05 PM
floepie's Avatar
Member
Default Leaking FPR?
I've been told my fuel pressure regulator is leaking - no, not air, but fuel. This sounds like a fire hazard waiting to happen. I also have some leaky gaskets - the valve cover and the tensioner gaskets, although there's never any pooling of oil in the driveway.
How many hours of labor should I expects for the gaskets and FPR? Thanks...
Old Dec 10, 2007 | 01:11 PM
cincyTT's Avatar
I'm make believe
Default RE: Leaking FPR?
The fpr isnt something that can go bad. there isnt any moving parts. Why would someone tell you this?
But the gaskets are about $45 for both at ecstuning.com and takes about 3hours for doing it for the first time. Its simple and just takes a little time. The fpr is even easier (its held on by a clip), but im sure yours doesnt need changed.
Old Dec 10, 2007 | 02:41 PM
acetrebo's Avatar
I have had a FPR go bad before (not on the audi), so it can happen. Maybe it gets clogged or something, but they can fail.
Old Dec 10, 2007 | 03:12 PM
floepie's Avatar
Member
ORIGINAL: cincyTT
I'm not quite sure why they would say that, but it is a reputable shop that specializes in foreign cars. I'm going to get a second opinion on that then. He claimed fuel was leaking out of the FPR, but perhaps it's coming out of one of the feeder lines. I don't really smell any fuel under the hood, so if it is leaking, it can't be that bad, but nothing to take too lightly either I suppose.
I was quoted 3.5 hours labor for those 2 gaskets and the fpr. That sounds a bit excessive, doesn't it?
Old Dec 10, 2007 | 03:18 PM
acetrebo's Avatar
No, not according to cincy's post:
So, 3 for the gaskets, another .5 for the FPR, sounds close.
Old Dec 10, 2007 | 04:22 PM
cincyTT's Avatar
I'm make believe
Well you can get a used fpr from here or vwvortex (you need a 4bar) for ~$20 shipped or $35-45 new. But seriously, if you have any time or car knowledge, do this yourself. Its not hard at all and will save you $200+ ($60/hr) for the job. There are plenty of how tos for this stuff.
Old Dec 10, 2007 | 06:58 PM
Jovian's Avatar
As cincy said this is a really easy task. The FPR replacement is literally 1 e-clip that you need to remove. But I also suggest cleaning around the FPR so debirs dont fall in before removing the e-clip
The gaskets are also pretty easy, hardest part is lifting the top off and not having it snag on athe threaded bolts. I suggest either getting another person to help you with this or get on a step ladder so you can get directly over it and pull straight up. This link here will give you info on how to do the gasket https://www.audiforums.com/m_61552/tm.htm
Tirrany2000
Sep 2, 2008 08:26 PM
Jc61990
Aug 22, 2008 11:48 AM
darkminotaur
Jan 3, 2008 11:51 AM
Bryceaudi
Jul 31, 2007 03:42 AM
Dudek12
Jan 21, 2007 07:23 PM
