leaking water in the interior
Old Aug 17, 2006 | 10:04 PM
germancarmaniac's Avatar
Default leaking water in the interior
alright, so the past few hard rains i have had about 2 inches of sitting water in my rear drivers side floor board. I took my headliner down and cleaned the sun roof drain in the rear and in the front. Everything is hooked up right and im still gitting water in. WTF? also when i park with my nose facing down i dont leak but if the front of the car is up, Holy sh*t, its like a freakin waterfall from somewhere. Please help. Thanks guys.
Old Aug 18, 2006 | 12:44 AM
TDRILL's Avatar
Default RE: leaking water in the interior
This problem was posted maybe a week or so ago.
https://www.audiforums.com/m_148032/tm.htm
Check this out and see if it helps you at all. Let us know what you find.
Old Aug 18, 2006 | 12:55 AM
tambo916's Avatar
I get a similar problem, but it is not coming into the interior. Mine is on the drivers side front door. When I open the door after a decent rainstorm there is a bunch of water sitting between the door and sill. I can't figure out if the window is off track or if it is something else. Could it also be a clogged sunroof drain? I also can't tell if the water is draining from inside the door or if it is just sitting between the sill and door.
I have a pretty good idea on how to take the door panel off, but I am not sure if I would be able to see if the window is out of alignment or even how to fix it. Window seems to go up and down fine. Although it does make a slight clunk when it goes all the way down.
Old Aug 18, 2006 | 02:11 AM
TDRILL's Avatar
I am not sure where your water is pooling (between the door and the sill?). You open the door and you see water pour out, but it isn't wet on the interior?
If you run into trouble getting the panel off, do a search, there was a post about that about a week ago too with a bunch of replys. Once you have the panel off, you can run the window up and down to see if there are any problems. If you are hearing a clunking sound, the track may be a little off or some other problem. You will be able to tell a lot better with the panel off so you can see and hear the window mechanism.
Old Aug 18, 2006 | 02:24 AM
toyolla86's Avatar
how do you take off the headliner and mess with the sunroof
Old Aug 18, 2006 | 01:39 PM
tambo916's Avatar
Yeah it is weird. Whenever I open the front driver's side door after a rain storm I get water in between the bottom of the door and the frame. I can't tell if it is just not draining from the frame properly or if there is actually water inside the door that is draining out when I open it. I will mess around with it this weekend and see. My front left tweeter is starting to cut in and out and there appears to be some sort of grease on the window on the inside up near the front mirror and tweeter, which leads me to believe the window is not properly aligned. Does anyone know how to reset it to the proper location? I will do a search in the threads as well.
Thanks.
RobinJ
May 2, 2014 11:03 AM
Theghost_85
Nov 18, 2010 05:43 PM
Theghost_85
Oct 25, 2010 02:33 PM
rmA4
Jun 12, 2010 12:13 AM
audimasher187
Jan 7, 2008 10:01 PM
