A little advice
Old Mar 29, 2007 | 01:59 PM
mnaudi's Avatar
Default A little advice
I have a few nagging repair issues I will be addressing now that the weather has warmed a bit. I am looking for some advice so that I won't be surprised during the repairs.
I am planning on doing rear brakes and replacing the radiator. I may do the alternatorsince I will be in there (it still works but is loud. should I be concerned or let itgo?)I am just wondering if there are any parts I should plan on getting, in addition to the main components. I am mostly concerned about the radiator. I don't want to have it all torn apart and realize I need to replace this hose or that bracket, especially considering alot of Audi parts aren't readily available. Mainly, what parts would be good to replace, just to be sure the job is done right?
This is my daily driver and all repairs must be finished in one weekend. I have done alot of this work before on various cars, especially brakes and alternators. The radiator will be new to me. Any advice from someone who has been there would be helpful. Thanks in advance for any guidance you can give.
Old Mar 29, 2007 | 02:16 PM
SacTown_Vlad's Avatar
Default RE: A little advice
most likely u need to have new hose clamps rest of the parts should be reused. y u wanna change your alternator, is it bad???...
how's your t/b?... how many miles you have?
Old Mar 29, 2007 | 02:36 PM
akielb's Avatar
couple more steps and you can do the t/b so if you have an extra $270 layin around order it from ECS.
Old Mar 29, 2007 | 04:13 PM
acetrebo's Avatar
Is your radiator leaking or something? its pretty stright forward.
Are you replacing with stock RAD? If so, you wont need new hose clamps, or anything else for that matter.
Otherwise, you probably will.
Replace thermostat while you are at it, maybe coolant temp sensor as well, just to be safe, although either of these can be done fairly easily with the rad in, so not a huge concern, they could wait until they fail, if ever.
For the rear brakes, you will want to get the caliper tool to turn the cylinder while compressing it.
Other than that, just make sure you properly bleed the cooling system when you are re-filling it.
Old Mar 29, 2007 | 04:22 PM
JohnnyBravoA4's Avatar
alternator is big money.. i would wait till it craps out.. 280-500 depending on which one you have
Old Mar 30, 2007 | 01:53 PM
mnaudi's Avatar
Thanks for all the advice. JohnnyBravo, I found them for as little as $180 (rebuilt Bosch), i think at getcool parts.com. As for waiting for it to crap out completely, this is my daily driver and don't want to be stranded.
I have 103,000 on the car and the TB was done at 75,000. Good to go.
Old Mar 30, 2007 | 01:56 PM
yea but do you have a bosch on your car.. the part number has to be a match..
gshultz75
Apr 26, 2013 01:22 PM
AKDachiba
Apr 10, 2013 11:51 AM
yamaharider11161990
Feb 16, 2011 07:57 PM
purepowerfit
B7 Models
Mar 21, 2008 06:39 PM
DEKMax
Oct 11, 2006 05:52 AM
