Losing Boost?
Old May 14, 2006 | 10:25 PM
thizzwatitiz's Avatar
Default Losing Boost?
it seems as though when i push my car pretty hard for a little while, i start to lose alot of boost, mostly in 3rd gear. any idea of why this is happening?
Old May 14, 2006 | 10:33 PM
onepoint8tee's Avatar
Default RE: Losing Boost?
Give more details on your car.. Do you have a boost gauge?... Its a good idea to get one of those for diagnosing boosting issues. You could be going into limp mode, or you could be experiencing heat soak. Or a boost leak, but if its random, probably one of the first 2.
Old May 14, 2006 | 10:38 PM
Sorry, yeah its a 2000 A4 1.8TMQ w/ apr chip and airbox mod. But yeah its mostly random, it just feels like i lose a ton of boost, this summer i will get a boost gauge though. What exactly is limp mode?
Old May 14, 2006 | 10:45 PM
ORIGINAL: thizzwatitiz
Well i just say limp mode because its more fun and is what most people call it, or confuse it as, but what i mean by it is closed loop mode where boost/fuel/timing is set back to stock parameters to prevent damage to something... It can happen if you over boost, or if the ecu detects something that is off. Its meant to protect your engine. It happens a lot when you first get chipped while the ecu is adapting, or some people experience it with manual boost controlers or N75 race valves that cause over boosting. Limp mode is technicaly where the tranny goes into a fail safe mode itself and is basicaly the same concept as closed loop, but for the tranny... Not exactly, but something like that.
Old May 14, 2006 | 10:54 PM
well i was thinkin what it may be is when it gets so damn hot in there, the turbo hose is collapsing, because i have heard that at high heat the oem hose collapses. So i may spend the 250 bucks on a ATP hose kit which wont collapse. Correct me if i am way off here.
Old May 14, 2006 | 10:59 PM
Well i guess that could happen, i havent experienced it that i know of... But i guess the hotter it gets, the more easily it can bend or collapse.. but id check out the classifieds for a used samco hose first because they are way over priced new.
Old May 14, 2006 | 11:09 PM
good idea, ill check the classifieds or just go for the one on rennart.com
Old May 14, 2006 | 11:12 PM
id get a boost gauge first.
Old May 14, 2006 | 11:17 PM
kextyn's Avatar
ORIGINAL: onepoint8tee
Umm...what? I'm confused. I may not know exactly what limp mode is for Audis but I thought it just limited you to like 35mph or something like that. This whole closed loop thing doesn't make any sense. Can someone else clarify this?
Old May 14, 2006 | 11:19 PM
Nah... I dont know ****.
