losing a small amount of boost
Old Mar 12, 2007 | 11:11 PM
audi_pa's Avatar
Default losing a small amount of boost
So i was driving the car this weekend and notice that the boost guage was only going up to barely 15psi. It has always been between 18-20 psi consistently for over a year now. So what do i do here? I heard the pvc valve can rob me of 2-3 psi. do i do a boost leak test? the car has 63K on it.
Old Mar 12, 2007 | 11:18 PM
x1rider's Avatar
Default RE: loosing a small amount of boost
A boost leak test could help you rule out a few reasons why you are loosing boost. Check out the DIY I posted on AG, it's fairly easy to do yourself. (the 2nd link is just an upgrade to the kit)
http://www.audigeeks.com/forums/index.php?topic=2034.0
http://www.audigeeks.com/forums/index.php?topic=2139.0
Old Mar 13, 2007 | 03:46 AM
aznknites's Avatar
I had a boost leak in the L-tubes... might wanna take a look at those quick and easy to check for..
Old Mar 13, 2007 | 04:01 AM
auditech79's Avatar
Hook up a vaccum pump to your turbo recirculation valve where the vaccum line goes into it and see it holds vaccum. If it doesn't its toast, replace that first then check for the hard stuff.
Old Mar 13, 2007 | 04:05 AM
i2onnel's Avatar
I have APR /w Milltek Exhaust
My boost hits 15-16 PSI.
Then of course falls back down to around 10 PSI.
PottsyA4
May 9, 2009 10:02 AM
mizzike2555
May 29, 2008 11:04 PM
ADubyaD
Apr 17, 2007 10:22 PM
mschwyter
Jan 2, 2007 10:10 PM
itsquattro
Dec 12, 2006 09:47 PM
