loud buzzing noise
Old Oct 24, 2006 | 09:52 PM
audibri02's Avatar
Member
Default loud buzzing noise
Ok heres my problem I accidently let my fuel light come on and thats when the noise started it sounds like its the pump. I am afraid that because I let it get so low that it pick up something in the tank. The car has 49,530 miles I wouldn't think that the pump would go bad that some ,but with the luck I am having with this car I wouldnt be suprised. Anyways the noise happens when driving sitting still it doesnt matter it does it all the time sounds like a loud buzzing not like normal fuel pump operation. It gets higher pitched at times to. Someone please give info if any thanks.[:@]
Old Oct 24, 2006 | 09:59 PM
twiggy114's Avatar
Default RE: loud buzzing noise
Do you have bee's in your car???
Old Oct 24, 2006 | 10:15 PM
audibri02's Avatar
Member
I'm asking for help not smart *ss remarks but thanks
Old Oct 24, 2006 | 10:46 PM
twiggy114's Avatar
Info I got from someplace... might help..."The fuel pump should be running all the time that the engine in your car is started and running. You should not be hearing a loud buzz from the fuel pump. You may have a faulty fuel pump or a plugged fuel filter. The fuel pressure is controlled by a fuel pressure regulator and could also be faulty. "
Old Oct 25, 2006 | 03:16 AM
Specialized's Avatar
i feel like the only reason i read this forum is for the smart *** remarks(not being sarcastic)
Onufry
Oct 11, 2007 09:05 AM
terminaltone
Oct 3, 2007 01:57 AM
supercoupe91
Jul 2, 2007 08:45 PM
audi82
Jan 23, 2006 07:13 AM
