Loud Screeching noise..
Old Jul 8, 2007 | 06:37 PM
02A418T's Avatar
Default Loud Screeching noise..
Just got my car back from the tuning shop.. Its been 3 days and Ive been through 2 coil packs and now under moderate to heavy accelleratin theres a LOUD screeching noise coming from the engine.. The car is running fine, So maybe its some type of hose lose or something. Any ideas? Hopefully something I could just fix myself..
Old Jul 8, 2007 | 07:27 PM
auditech79's Avatar
Default RE: Loud Screeching noise..
Pull off the serpintine belt and run the engine and see if the noise is still there. That will tell you if its belt driven or not.
Old Jul 10, 2007 | 12:38 AM
02A418T's Avatar
I just realized the car only does it when warm.. Basically once it gets close to halfway on the coolant temp gauge. What would this point to?
Old Jul 10, 2007 | 07:43 AM
hiwords's Avatar
poor some antifreeze on ur coolant and see if it helps. if not, do wut auditech79 said. if the sound is still there again, u got a diff problem
Old Jul 10, 2007 | 08:08 AM
ironman's Avatar
loud screeching is typically a belt, bring it back to the tuning shop and complain say you had all these problems since they worked on it. htey can figure it out probobly for free.
Old Jul 11, 2007 | 06:08 PM
02A418T's Avatar
Well I found out what it was, and figured Id post it in case someone has a similar problem and searches for it. The intake hose that connects to the turbo was a little loose, so under moderate-heavy boost air was leaking out making the squealing noise.
P.S-Why everytime I try to post pics it says 'Error saving file to disk"?
c_muller
Aug 20, 2015 10:01 AM
abcxyzzz
Dec 19, 2014 03:13 PM
mindflux
B7 Models
Nov 7, 2011 07:44 PM
James94
Jun 9, 2011 12:13 AM
akartis
Jun 10, 2009 02:12 PM
