Low Beam Replacement?
Old Oct 26, 2007 | 11:14 PM
a4cab's Avatar
Default Low Beam Replacement?
My right side low beam has burned out and need to replace. Called the dealerand they told me it's an H7 replacement. The low beam on my car ('04 A4) looks likethe lens for HID. He said it was a halogen.After looking at it, I'm wondering if he got mixed up and told me the high beam bulb number (it's a halogen).
Has anybody changed the low beam on this model?Is it HID as I suspect? Any tips on replacing? Thanks
Old Oct 26, 2007 | 11:17 PM
hiwords's Avatar
Default RE: Low Beam Replacement?
just take it out. it'll say on there wut it is.
Old Oct 27, 2007 | 01:26 AM
cstarky15's Avatar
well the highbeams are H7's. http://www.sylvania.com/ConsumerProd...lacementGuide/go there it will tell you. but the low beams are D1S.
Old Oct 27, 2007 | 01:34 AM
ImTheDevil's Avatar
Here's what a xenon bulb looks like:
http://www.strictlyautosport.com/images/9006.jpg
Here's what a halogen bulb looks like:
http://www.hidlook.com/catalog/images/h10s.jpg
That should show you all you need to know to determine what you have. The halogen is a 9006 or similar, so your H7 will look a little different, but you should be able to tell the difference between the two VERY easily, and then you'll know what you're dealing with.
The other way to know is, when you shut your lights off, do they go out instantly, or fade out over about a second's time? If they instantly shut off, gone, they're xenon. If they shut down at the same rate as your fogs do, they're halogen.
Old Oct 27, 2007 | 11:29 AM
CRAZYHAWK's Avatar
HIDs have a yellow sticker behind the light, for high voltage.
Old Oct 27, 2007 | 06:29 PM
a4cab's Avatar
Thanks everyone. Replaced the bulb today and it's an H7 alright. No HID. Took out 3 screws, removed the light assembly and popped off the back cover. Single bulb. The lens fooled me. Easy to take care of.
Old Oct 27, 2007 | 07:00 PM
S_R_N83's Avatar
ORIGINAL: a4cab
Yes, just because you have projector housings doesn't mean you have HIDS
Old Oct 28, 2007 | 01:45 AM
cstarky15's Avatar
UPGRADE THOSE LIGHTS TO HID/XENON
MetalMan
Jan 13, 2019 12:18 PM
R3N3G4D3
Feb 1, 2013 12:28 PM
dtkelley2005
Oct 23, 2007 02:39 AM
drwoods
Jul 9, 2007 09:10 AM
streethawk
Jan 2, 2005 08:47 AM
