A6 low beam headlight replacement
Old Jan 1, 2005 | 06:16 PM
streethawk's Avatar
Default A6 low beam headlight replacement
Both my low beam headlights on my 2003 A6 2.5 TDI have recently expired [have checked fuses etc. - all aok]. Can you help me to gain access to the lamps to replace them. The handbook says "refer to dealer" - that usually means a minimum of an hours labour just for the privilege!!!
[sm=thanx.gif]
Old Jan 1, 2005 | 06:57 PM
Jestnomen's Avatar
6th Gear
Default RE: A6 low beam headlight replacement
did they both go out at the same time? usually that means there is a problem with the switch, not the bulbs.
Old Jan 2, 2005 | 06:19 AM
streethawk's Avatar
Hi Jestnomen
Both went out almost at the same time but the units themselves are cloudy and grey which makes me suspect that the units have gone but I hear what you say about the switch. It actually happened while the car was being driven which makes me tend to rule out the switch. However, what are the odds that 2 low beam units blow at the same time without something causing it hmmmppphhh!!!
Old Jan 2, 2005 | 08:47 AM
Jestnomen's Avatar
6th Gear
You may want to bo invest in a cheapy 12 volt tester or a multimeter. Check to see if the headlights bulbs are getting 12 volts, it not then it's a switch problem. The low bean projector is suppose to be cloudy as it's like a magnifying glass, you should not be able to see the bulbs by nature. Hope you sort this out!
R3N3G4D3
Feb 1, 2013 12:28 PM
exmerc
Aug 13, 2008 04:21 PM
Blue01TT
Mar 8, 2008 01:52 PM
drwoods
Jul 9, 2007 09:10 AM
rifishman
Aug 5, 2005 10:38 AM
