low boost
Old May 2, 2006 | 07:58 PM
Dunzie182's Avatar
Default low boost
i just noticed today that my car isnt responding like it used to. i use to run about 15 pounds of boost and spiked at 16-17 with a chip, dv and n75...but today its only running at around 4 or 5. im assuming its a boost leak but i popped the hood and the turbo was smoking. any help would be great
Old May 2, 2006 | 08:22 PM
aRIf's Avatar
Default RE: low boost
limp mode ?
smoking ? oil/antifreze leak on turbo?
Old May 2, 2006 | 08:36 PM
BadLuckAudi's Avatar
yea it was probably in limp mode and the smoke probably isnt anything to worry about its just **** that got on there
Old May 2, 2006 | 09:26 PM
Dunzie182's Avatar
how do i get it out of limp mode? sorry for the noob question
Old May 2, 2006 | 09:28 PM
onepoint8tee's Avatar
haha.. why dont you ask your urologist..?
Get your car scanned for fault codes at autozone or someplace like that.. They should do it for free.
Old May 2, 2006 | 09:34 PM
lol thats bad, lol it should be ok after you start it again, but yea have the codes checked for sure
ORIGINAL: onepoint8tee
Old May 2, 2006 | 11:06 PM
Dunzie182's Avatar
well i went to autozone and of course they dont have (i hate the autozone by me). guess ill be bringing it to the dealership tomorrow and hopefully i can borrow their VAG for a couple minutes. in the meantime, what could be some things that cause this?
Old May 2, 2006 | 11:19 PM
Jeff's Avatar
Zombie Defense Force
just disconnect your negative terminal on the batter with the car off for about 30 seconds and u will be out of limp mode if that is the problem. dont take you car to the dealership yet try this first. if you take your car there they will charge you 110 bucks to do what auto zone would do for free. and u cannot borrow anything from them with out giving up you verginity and both legs
Old May 2, 2006 | 11:40 PM
david9999's Avatar
If you are going to disconnect your battery, make sure you have the radio unlock code.
You have either gone into limp mode, have a vacuum leak, a bad diverter valve, or a stuck wastegate.
Old May 2, 2006 | 11:48 PM
Jeff's Avatar
my radio has never gone into safe mode even when i have both terminals off the battery
