Lower control arm and brake question
Old Nov 27, 2006 | 08:17 PM
hacgumyu's Avatar
Default Lower control arm and brake question
My A4 97 have the lower control arm recall problem, but i found out too late. stupid Audi stop that recall campaine so no more free repair. not I want to know where to get just the front lower control arm cheap online. and is that a FAQ tutorial on how to fix this myself?
Secondly, my brake feels very very weak. the brake pedel is so firm and I have to step HARD to make fast stop even the pads in good shape, so I think I need to flush the brake fluid and change brake line, is there a FAQ on these?
thanks
Old Nov 27, 2006 | 08:19 PM
captcaos2002's Avatar
Default RE: Lower control arm and brake question
What state are you in? Autohausaz.com or purems.com will have the single control arm for you
Old Nov 27, 2006 | 08:21 PM
hacgumyu's Avatar
Washington state.
any good picture tutorial on how to do the work?
Old Nov 27, 2006 | 08:34 PM
acetrebo's Avatar
also ecstuning.com is a good site.
There are a lot of good writeups for stuff at audiworld under their technical section.
Old Nov 28, 2006 | 03:46 AM
hacgumyu's Avatar
can you guys recommend some brake pads and brake fluids to use? is stainless steel brake line neccessary? OEM line work well too?
thanks again
Old Nov 28, 2006 | 04:29 AM
a4r6's Avatar
If you don't know what your doing its not that easy.. Sucks man I had to do upper and lower on mine... Green stuff
Old Nov 28, 2006 | 04:32 AM
onepoint8tee's Avatar
www.getcoolparts.com seems to have the best deals/shipping costs for control arms. They carry the better upgraded Meyle brand you should be looking for.
Old Nov 28, 2006 | 04:34 AM
ORIGINAL: hacgumyu
thanks again
Also, anything at www.getcoolparts.com is good. Mintex pads are a good popular cheap pad, use only audi fluids like pentosin brand. Stainless lines arent necessary but help. Why do you need new brake lines anyway???
Old Nov 28, 2006 | 01:34 PM
acetrebo's Avatar
pads - mintex red are good and cheap ($45) or get hawk or ceramic performance if you want to spend the money (double?)
Steel lines - go with them, they dont expand like the rubber, so you get a little bit more responsive feel in the brake system. Not a huge difference, but not a huge cost either, definitely worth it.
Fluid - use the audi reccomended fluid. Should tell you on the resevoir lid. DOT5? Just use what is reccomended in the manual.
mtroxel
Jun 14, 2012 10:48 PM
jdahlen24
Aug 25, 2011 09:50 PM
vgo
Nov 22, 2008 12:04 PM
soundguy
Apr 9, 2008 02:24 PM
