MAF sensor?
Old Nov 22, 2007 | 10:45 AM
smootboy5's Avatar
Default MAF sensor?
Hey I have a thread already started, but I am in some desprate help on this i need my car working. I installed a K&N cold air kit and I think it threw my MAF sensor out of whack. The car will not start, just crank over, is there any way I can start running tests on my system or bypass it. Any help is greatly appreciated.
Old Nov 22, 2007 | 10:47 AM
onepoint8tee's Avatar
Default RE: MAF sensor?
You either put the MAF in backwards, or forgot to hook something else back up. Dont double post, bump your originalthread... [:@]
And since I had to go search for your original thread on the subject for clarification on what was already discussed, I just wanted to let you know that its impossible to hook the ICM/MAF wiring harness up to each other. Its not the same kind of plug...........
Which way is the arrow pointing on the MAF? Towards to the filter or towards the intake piping?
Old Nov 24, 2007 | 03:57 PM
dankhound's Avatar
Try unplugging the maf. It will make the ecm go off a set airflow per rpm and ignore the maf.
Old Nov 24, 2007 | 04:00 PM
rbrtech's Avatar
3 times now come on. People have given you answers each time you just dont listen
neomaxddr
Apr 1, 2009 03:16 AM
