making own clear corners
ORIGINAL: brrman
Eh? Did you even see my earlier post in this thread? Keep in my that some people muck everything up, no matter how easy it is. So for someone to ask that question of themselves before they cut into a $500 set of headlights is quite acceptable.
I repeat:
You aren't going to "...muck it up". It requires drilling tiny little holes that are later sealed up with clear silicone. That's the "damage" you'll cause to your light housings - nothing else.
FYI: You risk far more damage by chipping your car. {Turbos and manifold seals/gaskets vs headlights.}
Maybe it's an individual thing. Everyone has an individual tolerance for risk. You think a chip is less risky than a clear corner mod. Maybe you concluded that the risk of a chip is long term potential failure whereas the headlight mod is an immediate risk - if the clear corner mod fails, it's going to fail at the time of modification. For that philosophy I will concede. You're right.
I guess I was fortunate enough to watch someone do a clear corner before I attempted mine. That gave me confidence and my perception of risk was minimized.
And as for my chip, I researched the risks, investigated and determined what the best maintenance procedures are in order to minimize long term failure and, now, I try to adhere to those procedures.
Ironically, I see that you decided the risk of chipping your car was OK; even though the potential "muck up" is financially greater than the "muck up" of a headlight.
And my earlier post said:
lots of people have done that mod - it comes out nice if you take your time - plug up the holes with clear silicone.
I was quite aware of the risks involved with the chip, and had done my research - as I do with every mod I make.
Never know when you'll get a re-enactment of "When Dremels Attack".
Obviously a misunderstanding. I thought you were speaking for yourself, not for anyone elses benefit.... Kind of why I kept going back to your quotes.
No, I haven't seen the inside of your car - gonna post pics?
[8D]
hmm. there's lots of pics around of my car. but's here a couple...
Some mods I have done myself...
Chip (obviously)
Boost Gauge in driverside middle vent
Added lower foglights using stock switch
DIY sport grill trim
Independent rear fog mod
Autodim rear view mirror
Ambient cabin red led lighting
Brush aluminum tip shifter plate
Carputer (mp3, navigation, VAG)
USB 2.0 integrated in console
indash 7" lcd touchscreen
Moved cig lighter to under armrest
Moved HVAC to where ashtray was
5 1/2" Speakers in front doors with custom mounting brackets
Custom fiberglass sub enclosure
Custom amp rack, etc
I had my entire interior out at one point doing the computer/stereo install... Thats was a learning experience for sure.
Some random pics
Chip (obviously)
Some random pics
Some very interesting ideas put to good use.
I like the relocated HVAC; very smooth - looks OE.
Did you do the Carputer and the integrated USB from an idea of your own or did you go off of a tech article?
ORIGINAL: imolas4
Was a major project, and a major PITA at times. But I like having 5000 songs at my fingertips, movies, and navigation when I need it. That HVAC reloation was probably the most frustrating thing I had to do.
