Manual Trans oil
Old Jul 19, 2005 | 06:00 AM
MadIce's Avatar
Default Manual Trans oil
97 2.8l, 5spd, FWD
How much oil is the gear box supposted to have in it? I searched a bunch of places and can't seem to get a solid answer [>:]
Old Jul 19, 2005 | 02:08 PM
MadIce's Avatar
Default RE: Manual Trans oil
Tried to call audi, they refuse to say... [:@]
Old Jul 19, 2005 | 03:19 PM
david9999's Avatar
I can try to look it up later, but you fill it until is starts to leak out the fill hole.
Old Jul 19, 2005 | 03:38 PM
MadIce's Avatar
ORIGINAL: david9999
Ya see thats what I thought, but then I'm not exactly sure if I'm using the correct hole to fill it up with (it seems to be the most logical at least). Its a bigger sized hole that is secured with a plastic peice (kinda looks like a sensor with a spring inside it, but no wires).
*FYI: When I dumped the oil it only had 2 quarts in it?
Old Jul 19, 2005 | 06:15 PM
david9999's Avatar
I'd suggest investing 15 dollars in a chilton's or Haynes manual which had pretty good pictures for basic maintenance, etc
Old Jul 19, 2005 | 06:28 PM
MadIce's Avatar
ORIGINAL: david9999
Ya I was planning on picking one of those up, but haven't seen any at local part stores and kinda lazy to order online.
Old Jul 19, 2005 | 06:59 PM
BLAZEDUPBEE's Avatar
i think i used 4-5 cant really remember when mines was changed during the winter..
Old Jul 20, 2005 | 02:54 AM
MadIce's Avatar
I've seen answers from 2-5? Can anyone who has a bently or similar manual look this up? []. I need to get this car out of the garage. I'm sure the 3 is fine, but I would prefer to be on the safe side (I can take a whole trans apart, yet not know how much fluid [&:])
Old Jul 20, 2005 | 03:22 AM
MadIce's Avatar
Well I had to goto a German VW site (luckly its written in 1/2 english), but I found a lot of factory type assembly instructions. According to the factory specs it should only take 2.4Q's....
http://volkswagen.msk.ru/transmissio...2_overhaul.pdf
ryal
B8 Models
Dec 14, 2013 05:42 PM
rshepler217
Dec 12, 2013 10:36 PM
secmil
Nov 26, 2007 11:25 AM
rbrtech
Jan 9, 2007 03:47 PM
mat.martins
May 15, 2006 04:01 PM
