MAP & MAF Bad
Old Feb 7, 2007 | 06:53 PM
turbo kraut's Avatar
Tech Guru
Default MAP & MAF Bad
here is the question, the map is definatly shot, but the maf was giving me some good readings and not so much so the other times
could i replace the map sensor and see if that is fine then get a maf if it isn't or should i just break down and do both at the same time?
any help would be appretiated
Old Feb 7, 2007 | 06:57 PM
onepoint8tee's Avatar
Default RE: MAP & MAF Bad
Try cleaning the MAP sensor. They are known to get dirty and give bad readings. Why do you think the map is shot? have you tried cleaning the maf?
Old Feb 7, 2007 | 06:59 PM
techbod's Avatar
if you have a MAF you dont have a MAP ( take my word for it )
Old Feb 7, 2007 | 07:03 PM
Tech Guru
i was at the mechanic today, for my 0171 cel
had them test it, and they said both sensors were going bad gone
he put in a new(map) thrust sensor and it made the maf act better but not completely right
i think the #'s for the map are 70's or something and they were bellow, maf is 100's and it was well bellow
put in a new map to test and it was throwing 104 and "normal" readings most of the time
Old Feb 7, 2007 | 07:04 PM
Tech Guru
i tried cleaning the maf and that did nothing to fix it, haven't tried cleaning map(thrust) sensor
techbod's Avatar
made lots of friends on the lexus site it seems they need a tech for basic things like cleaning and polishing but mechanics are rare
Old Feb 7, 2007 | 07:08 PM
Tech Guru
i don't understand that last post
but i was told that we have both
Old Feb 7, 2007 | 07:11 PM
techbod's Avatar
do we?? im now veryinterested[:-]
Old Feb 7, 2007 | 07:12 PM
yes you have both a maf and map.
I cleaned my map sensor a couple weeks ago just for the hell of it... it was dirty. Dave-map is in the intake manifold and maf is in the airbox.
Just get a toothbrush and rubbing alc. and clean it.
Old Feb 7, 2007 | 07:15 PM
techbod's Avatar
I need to check this out because I think you taking the P big style
