MAP & MAF Bad
Old Feb 7, 2007 | 07:18 PM
techbod's Avatar
Default RE: MAP & MAF Bad
hahahahahahaha
Old Feb 7, 2007 | 07:19 PM
turbo kraut's Avatar
Tech Guru
the map or what he showed me to be the map, the thing he replaced was right behind the left head light
i will drive it tonight and tomorrow and see if it comes back on, then go from there
onepoint8tee's Avatar
Can never understand what youre trying to say man... ^ Sorry.
turbo kraut- i was thinking about a different sensor.. I can see youre tlaking about the sensor in the IC now. I cleaned that one too
Old Feb 7, 2007 | 07:22 PM
Tech Guru
you mean in all my posts you never understand me?
Old Feb 7, 2007 | 07:25 PM
techbod's Avatar
MAP = manifold absolute pressure
MAF =Mass air flow similar to map but measured different by the ECU generally by heated wire but that's old generation
Old Feb 7, 2007 | 07:27 PM
Tech Guru
i know what they all are and where they are, i am thinking audi call the thrust sensor a map, so stupid people like me will know what it is/means, the tech said that it is a thrust sensor but they call it a map
Jeff's Avatar
Zombie Defense Force
i had both. because i ran with a maf and with out one depending on the day and if the maf was working or not
Old Feb 7, 2007 | 07:28 PM
  #18
no, i can never understand what avant80@2.6 is saying. The map sensor is best described as a "boost sensor" because it senses boost and reports it to the ecu.
Old Feb 7, 2007 | 07:41 PM
  #19
Tech Guru
right, that is why my boost has been at 5, he "fixed" it and i am boosting at 10
can i unplug my map and just run on my maf? will it hurt the car?
i just spent almost 500 getting everything tested, and my wheel bering replaced, which i would of done, but burr is it cold and now i need to replace my front brakes
Old Feb 7, 2007 | 07:46 PM
  #20
techbod's Avatar
if the exhaust isn't on right you might have a pull to the left which could we are you seats out due to the position of your key board and the screen will be out of focus making driving dangerous
