mbc, n75h, electronic boost controller?...
DO NOT GET THE 3 POINT MBC!!! YOU WILL HATE LIFE!!!
You can only adjust the psi to ~15psi or so and they cannot be run inline with the n75 if you want to do that.
now just to clear this up tho... you dont HAVE to get this when upgrading the turbo right? As in, if you buy a in-cabin electronic boost controller it will do the same thing right? Only difference is mbc is manually dont under the hood? As you can tell im not to knowledgable with this
either get the forge unos (mbc) or get the apexi vrc (ebc). i just installed it on my car and omg its so much better then anything else i have had. its easy to tune and i dont spike or drop off that much. holds boost like a champ.
I would go with:
My turboxs hpbc
Turbosmart in-cabin
Or cheaper alternatives
Turboxs knock off (voodoo) out of stock i guess
Turbosmart knock off - My brother wanted to try this and i was amazed on how well this one works. I would go with this if you want an in-cabin one.
My turboxs hpbc
Turbosmart in-cabin
THANK YOU!!! thats what ive been trying to get at the whole time. Anywebsite recommendations on the Apex'i or just get it through there main site. Also, from along time ago i remember these were used on hondas (used to own one) does the avc-r work good with Audi? Thanks again
