mbc, n75h, electronic boost controller?...
Old Apr 12, 2007 | 01:20 AM
cincyTT's Avatar
I'm make believe
Default RE: mbc, n75h, electronic boost controller?...
DO NOT GET THE 3 POINT MBC!!! YOU WILL HATE LIFE!!!
You can only adjust the psi to ~15psi or so and they cannot be run inline with the n75 if you want to do that.
Old Apr 12, 2007 | 01:23 AM
A4Rollin's Avatar
now just to clear this up tho... you dont HAVE to get this when upgrading the turbo right? As in, if you buy a in-cabin electronic boost controller it will do the same thing right? Only difference is mbc is manually dont under the hood? As you can tell im not to knowledgable with this
Old Apr 12, 2007 | 01:26 AM
Jeff's Avatar
Zombie Defense Force
either get the forge unos (mbc) or get the apexi vrc (ebc). i just installed it on my car and omg its so much better then anything else i have had. its easy to tune and i dont spike or drop off that much. holds boost like a champ.
Old Apr 12, 2007 | 01:27 AM
chaos92287's Avatar
yup. i have the exact setup your putting in (only i have a testpipe and you have a hfc) im not running any mbc, or ebc right now. you can put it on later.
cincyTT's Avatar
I'm make believe
I would go with:
My turboxs hpbc
Turbosmart in-cabin
Or cheaper alternatives
Turboxs knock off (voodoo) out of stock i guess
Turbosmart knock off - My brother wanted to try this and i was amazed on how well this one works. I would go with this if you want an in-cabin one.
Old Apr 12, 2007 | 01:36 AM
A4Rollin's Avatar
so in-cabin digital ebc's are out of the question?
Old Apr 12, 2007 | 01:39 AM
Jeff's Avatar
no y would they be out of the question. they have so much more potential then a mbc. ebc ftw
  #18
cincyTT's Avatar
I'm make believe
If you want to drop some $$$ get a apex avc-r or a greddy profec spec II
Old Apr 12, 2007 | 01:44 AM
  #19
Jeff's Avatar
the apexi is easier to tune and use imo. it also has a lot more features.
Old Apr 12, 2007 | 01:48 AM
  #20
A4Rollin's Avatar
THANK YOU!!! thats what ive been trying to get at the whole time. Anywebsite recommendations on the Apex'i or just get it through there main site. Also, from along time ago i remember these were used on hondas (used to own one) does the avc-r work good with Audi? Thanks again
