mbc, n75h, electronic boost controller?...
so you can get to lemmy settings with having vag com running at the same time or via vag com??? Explain that exactly? Vag com is the software/emulatormade by theRoss-Tech company, so I dont know how you could "use" Ross-tech with it. Huh?
i ran the s-afc with a modified chip from apr. then i took the afc out and ran an atp chip with a lemm tune. the afc would change the maf readings and with the maf readings all messed up you cannot tune with lemm so the afc came out
You "use" a vagcom cable ross or other to let you use lemmy. You use it to make the connection from computer to the ecu. You dont use the Ross-tech sw while using lemmy. Some fake ebay cables dont work well with lemmy so a real cable works best.
ORIGINAL: onepoint8tee
I dont have personal experience with lemiwinks, but i have also heard that an adaptation, or even simply clearing fault codes will reset any modified parameters made with lemmy.
so with all this talk about not liking the safc, do you think the apexi avcr will be good for my 2001 with K04, Giac K04 chip, intercooler, etc?? I want to buy this one preferably for a boost controller andsome other good stuff
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
