mbc, n75h, electronic boost controller?...
Old Apr 15, 2007 | 05:06 AM
  #71
onepoint8tee's Avatar
Default RE: mbc, n75h, electronic boost controller?...
so you can get to lemmy settings with having vag com running at the same time or via vag com??? Explain that exactly? Vag com is the software/emulatormade by theRoss-Tech company, so I dont know how you could "use" Ross-tech with it. Huh?
Old Apr 15, 2007 | 05:24 AM
  #72
Jeff's Avatar
Zombie Defense Force
i ran the s-afc with a modified chip from apr. then i took the afc out and ran an atp chip with a lemm tune. the afc would change the maf readings and with the maf readings all messed up you cannot tune with lemm so the afc came out
Old Apr 15, 2007 | 05:25 AM
  #73
cincyTT's Avatar
I'm make believe
You "use" a vagcom cable ross or other to let you use lemmy. You use it to make the connection from computer to the ecu. You dont use the Ross-tech sw while using lemmy. Some fake ebay cables dont work well with lemmy so a real cable works best.
Old Apr 15, 2007 | 05:34 AM
  #74
Jeff's Avatar
ya lemm is its own program. and you use a obd2 port cable to tune
Old Apr 15, 2007 | 02:24 PM
  #75
2k S4's Avatar
ORIGINAL: onepoint8tee
I dont have personal experience with lemiwinks, but i have also heard that an adaptation, or even simply clearing fault codes will reset any modified parameters made with lemmy.
Nope, once they are in there, there in there, you can only clear them with Lemi.
Old Apr 16, 2007 | 12:44 AM
  #76
A4Rollin's Avatar
so with all this talk about not liking the safc, do you think the apexi avcr will be good for my 2001 with K04, Giac K04 chip, intercooler, etc?? I want to buy this one preferably for a boost controller andsome other good stuff
Old Apr 16, 2007 | 12:52 AM
  #77
Jeff's Avatar
yes it is just a boost controller. dosnet mess wiht ecu or anything at all
Old Apr 16, 2007 | 01:10 AM
  #78
A4Rollin's Avatar
sweet, btw jeff i talked to that guy sellin the ebc and imbuyin it tomorrow.... thanks bro
Old Apr 16, 2007 | 01:20 AM
  #79
Jeff's Avatar
sweet. i love mine. i can set the boost and it holds so much better then any mbc i have used
ref1590
Sep 11, 2009 12:25 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
dr_zoidberg
May 12, 2008 07:18 PM
jeff01
Jul 24, 2007 12:03 AM
SR71_BlackBird
May 3, 2007 02:14 AM
