misfire
Hello,
I have a 1998 a4 1.8t with a tap-1 stage 2 chip, custom exaust, k and n intake (no air box).
and all of a sudden with no warning, the car started to run rough, and had a loss of power.
when i pluged in the code reader, it gave me 2 codes, random misfire, and misfire on cly #3.
Here is what i have done.
i moved around the coil packs, to see if the miss followed the pack. it did not, still on #3
i pulled the injector rail to see if they were firing, they were.
i also moved the injectors around to see if the miss followed...it did not...still on #3
i did a compresion test, all around 125 psi....good for 80k
and yes i replaced the plug...
tap 1 is sending me a test computer
anyone have any other ideas??????
thank you in advance.....E
well good luck to you,
you can be shure i will post the result with my car....hopefuly that might help you...
i am convinced that it is the ecu, or in the wire harnes leading to it...
we will see when the test computer comes in..
E
E
Russ Heinrichs
Aug 18, 2021 12:39 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
